09-22-2015, 05:06 AM | #1 |
Fuel Sending Ground location ?
Hey can someone confirm for me where the fuel sender ground is supposed to bolt to on the frame.
Below is a picture of where it was before I tore it down (don't know if this was the factory location or not). Then a picture of what I have. If that is the proper location, I will have to make a longer wire. This one on the new sender is a little short. Thanks for any help on this one. Jeff.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
09-22-2015, 09:49 AM | #2 |
Re: Fuel Sending Ground location ?
I'm pretty sure it bolts to the rear crossmember but let someone else chime in that knows for certain.
09-22-2015, 11:13 AM | #3 |
Rear cross member is were mine was/is. First pic is correct.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
09-22-2015, 12:52 PM | #4 |
Mine is like first picture too.
09-22-2015, 01:53 PM | #5 |
Thanks guys. I guess the wire on the new sender must be a little shorter. I doubt I could pull it that far. Looks like I will have to crimp a longer one.
