Old 09-22-2015, 03:30 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Front bumper bolts question
71 Chevy
There are six bolts that mount the front bumper to the brackets. If you look closely, the heads on two of these bolts are more rounded than the other four. The other four come to somewhat a peak, similar to the mushroom in this link (ha!). http://pngimg.com/upload/mushroom_PNG3186.png
I think the two more rounded heads are for the top center. Can you confirm or correct?
Didn't see it when I took them off.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-22-2015, 03:33 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Front bumper bolts question
All six bolts are the same.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-22-2015, 03:56 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
The bolt heads will differ with the manufacturer. Get a full set form one source and replace the old ones so that they all look the same.
Frank
Old 09-22-2015, 05:23 PM   #4
cdowns
cdowns's Avatar
The bolts are all the same from the factory// i think that your bumper may have had bumperrettes on it at some time and somebody lost or destroyed some of the originals
Old 09-22-2015, 05:49 PM   #5
71CHEVYSHORTBED402
I'm planning to do this anyway. Note, this was the original bumper and the heads are not the same. That said, it could have been taken off at some point, before I got this in 1989.
The original owner had a slot cut out from the bumper and a boat launching hitch welded to it. Shame, the bumper is probably worth recycle only.
Tony
Old 09-22-2015, 06:21 PM   #6
67swb72klb
67swb72klb's Avatar
I believe the original GM carriage bolts have a higher dome than any replacement that I have seen so far
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-23-2015, 12:24 AM   #7
poway
Are the front bumpers on a 1968 chevy C10 the same for a 1968 GMC C1500? The one on the GMC needs to be replaced.
Thanks in advance for any info.
poway is offline   Reply With Quote
Old 09-23-2015, 01:48 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Not so sure about the '68 [and '67] GMCs but later GMC bumpers had those rolled-back rims under the Turn Signal/Parking Lamps so the bumper didn't eclipse half the running light. Chevys had those lights higher in the grille or '71 -'72 in the bumper itself.
Other than the cut-outs, the GMC bumper should be just like the '67-'70 Chevys.
Old 09-23-2015, 11:28 AM   #9
In The Ten Ring
I have my 1972 bumper off and the carriage bolts are unique (in my mind) in that the shiny heads appear to be due to a thin metal wrapped over the top and tucked into the underside of the head. I can see its edge under there.
All my bolts are uniform in shape.
In The Ten Ring is offline   Reply With Quote
