Old 09-23-2015, 07:52 PM   #1
In The Ten Ring
Re: Radiator support
Originally Posted by raggedjim View Post
You got that right! They were a bear to get off, I had to hacksaw the one on the passengers side off after tearing away the old mount.
Rg
That's bad. Well my core support is simply too far gone rust-wise to save. I am going to haul it off to the junkyard along with the passenger side inner fender. The rust was so bad where the inner fender and core support are bolted together, the core support broke around the bolts when I was trying to remove the nuts! I ended up using my Dremel Tool and cutting wheel to separate the two.
I should dump the outer fender on that side also but the rear of it could still be a patch panel for someone.
In The Ten Ring is offline   Reply With Quote
