steering column
I need to replace the shift collar on a 1982 gmc. I have no experience with this and need any help available. Also while I have it apart should I replace the turn signal assembly as well?
![]() Join Date: Jun 2009
Re: steering column
You would be better off getting a different steering column. It is relatively involve to do the shift collar. It takes specialty tools. If you are talking about the upper collar where the ignition switch is, that is pretty basic.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
