Old 11-22-2014, 12:54 AM   #26
Captainfab
60-66 Nut
Re: Power Steering Conversion for 60-62-answers
I don't quite understand how the pitman arm is causing a problem with the power steering pump. The pitman arm should be connected to the steering box and that should be positioned the opposite direction from the front cab mount. What steering box adapter plate are you using? The power steering conversion should work with a factory or original style replacement steering box and pitman arm.
Originally Posted by Saave1960 View Post
I have my 1983 c-10 pump mocked up in my 1960 but in order to get the stock 83 pitman lined up the gear box goes so far back that it hits the front left cab mount...is an aftermarket shorter pitman required to make this work?
Old 11-23-2014, 08:06 AM   #27
DakotaKid
For you guys that did this conversion, How close does your Centerlink get to the Crossmember? Mine gets really close. like within probably 1/8 to 1/4 of an inch.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 09-25-2015, 09:49 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by doobiebro View Post
Slepysal here are those pics I promised you....
I'm trying to track down exactly what collapsible shaft to use for the 60-62 trucks.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-25-2015, 11:41 PM   #29
slepysal
slepysal's Avatar
this is what I did with mine ( I know it is not collapsible) but it should give you an idea .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-26-2015, 12:23 AM   #30
Captainfab
60-66 Nut
Since your cab is a '65, is your steering column a '60-'62 or a '63-'66?
I have not done this, but I would think that a '73-'87 collapsible steering shaft would work.
Old 09-26-2015, 11:25 AM   #31
LostMy65
LostMy65's Avatar
It's presently a 60-62, but I have a 66 th400/th350 column I will be swapping in when I install my th350 tranny.
Old 09-26-2015, 01:19 PM   #32
aotte1
Not sure if this helps, some more info.
Just put an colapable Borgeson set-up in 1964 K10, for safety and really tight steering. Used two universal joints and a shaft. Not cheap but works really well. Used original shaft and cut some of it off, plus a little machine work on end connecting to one of the universal joints. This set up gets rid of the rag joint ( much tighter steering). The set-up allowes the steering shaft to be centered in firewall and cab, as the PS conversion moves the connect at the steering box out from the frame some, changing the original alignment of shaft.
Will post more info on parts/ process soon, here are a couple of photos.
Les
aotte1 is offline   Reply With Quote
Old 09-26-2015, 01:21 PM   #33
aotte1
Another photo
Old 09-29-2015, 11:33 PM   #34
bosephus
bosephus's Avatar
Originally Posted by aotte1 View Post
Another photo
That's really slick,I want one! Do you have any part# or links to this?
bosephus is offline   Reply With Quote
Old 03-25-2019, 04:49 PM   #35
demian5
demian5's Avatar
Got any better picture of the bracket on the frame before installing the box? And better pictures of the box bolted up? It looks like the top rear bolt bolts the box to the bracket.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
