Re: VIN Number Location??
They ran two steering boxes 73-79 then 80-87 only thing different is the 80 and newer used metric fittings on the ends of the power steering lines at the box.And the 2wd and 4x4 boxes are different also.Easy way to tell is look at the pitman arm if it has a big nut on the end its 2wd,If it has a bolt on the side of the pitman arm and has a slit in the pitman arm its 4x4.
