How do ya shine up your 1972 outer grill?
I am nearly ready for this job, cleaning up and shining up the outer grill of my 1972. How do I do it?
It has some paint overspray from Mr. Bondo some years before I got it and it has some rust from the grill brackets. Need that off too. |
Re: How do ya shine up your 1972 outer grill?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
My buddy used a commonly available drain cleaning fluid. It worked amazing to remove all the grit, grime, and stains. He then lightly polished and it looked like new!
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
But you do have to keep it polished, right?
It still looks good after 6 months of no polishing
Moderator
![]() Join Date: May 2007
Lye will strip everything off and give you a raw base to polish. You cannot polish a discolored grille due to the anodization. Do not leave lye (drain cleaner, oven cleaner) on it too long or you will ruin it. If you do not want the upkeep associated with aluminum it will either need to be re-anodized or parked in a garage, otherwise it oxidizes quickly and will need frequent polishing. I had my grille restored and did not re anodize. It is garage kept and I have only polished it once since then.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Wax helps, once it's polished, to keep it there. Ditto on can't polish anodized. It all depends on how far gone it is. Sometimes a super good cleaning will help it
