Old 09-28-2015, 04:05 PM   #1
C10_Nation
How to decide what drop I need
How did you figure out what drop you wanted? Did you get wheels first then drop or drop then wheels? Want to do just a coil drop.
C10_Nation is offline   Reply With Quote
Old 09-28-2015, 06:47 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: How to decide what drop I need
You have to decide what stance you prefer and go from there. Lowest coil only is about 4-6 any more than that requires cutting the bumpstop and frame. Here's mine lowered 4-6 spring only. Adjustable panhard bar 76 front suspension and flipped rear lower shock mounts.
Welcome to the board. The search function is awesome when researching questions that have been asked many times.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-28-2015, 07:00 PM   #3
C10_Nation
I want to have the fender well just over the tire or just above it.. I was thinking a 3 5 drop but your 4 6 looks killer. Just couldn't figure out if I needed wheels first or if I could go that low with stocks. Did you just use a tape measure to figure out approx where it would sit?
Old 09-28-2015, 07:38 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Drop first always.
Keith
Convert to disc brakes.
Old 09-28-2015, 08:42 PM   #5
C10_Nation
Thanks man
Old 09-28-2015, 08:47 PM   #6
CC69Rat
CC69Rat's Avatar
Im not sure what year or what type of truck you have but.. there are a lot of things to consider when you lower it.
With a 3/5 drop for example you're doing an "all spring drop" right now remember your truck has about 40yr old springs in it. They have likely sagged a little over the years so that 3" spring drop you're trying to achieve is going to only be about a 2" net drop.
Also a 3" drop spring can (didn't say always) but can make it a bit more of a challenge to get back into alignment specs.
In the consideration stage I usually suggest to think about using dropped spindles. It costs a little more up front but the spindle drop will yield 100% of your advertised drop. 2" spindle = full 2" drop. Also the dropped spindles will generally keep your steering geometry and alignment specs in check. You can also keep your stock springs or combine a 2" spring and 2" spindle for that full drop you're looking for. (3.5 net or so) 2.5" spindle and 2" spring is pretty common. If your truck is already disc up front (??) This is much much easier.
For the back, anything over a 3 or 4" drop I would suggest shock relocation and an adjustable track bar. The truck will ride better because the shocks are not at such a horizontal angle. The relocation will help get them more vertical.
The 4.5/6 drop kit from Early Classics is highly recommended. Just my thoughts
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-28-2015, 09:12 PM   #7
C10_Nation
Running a 71 lwb. Stock height, disc/drum combo. Thanks for the info.
