02-29-2008, 07:24 AM | #1 |
Wheelin' and Dealin'
my 65 build thread
hey guys finially got all my pictures on the computer and so here are a few .. not much to look at but it will be before christmas
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 Last edited by Hillbilly Deluxe 65; 10-08-2008 at 01:24 PM. |
02-29-2008, 07:25 AM | #2 |
Re: my 65 build thread
stripped cab
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 Last edited by Hillbilly Deluxe 65; 03-05-2008 at 08:18 AM. |
02-29-2008, 07:35 AM | #3 |
cool!!!
CHEVY ONLY Last edited by joe231; 02-29-2008 at 07:36 AM. |
02-29-2008, 07:47 AM | #4 |
Tot Roddin'
Lookin' good... keep us posted!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-29-2008, 09:13 AM | #5 |
Hollister, CA.
Coming along nicely !!
I noticed you have leafs, but also have the trailing arm mounts as well...what's the deal there ?? Is that how it came ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
02-29-2008, 06:21 PM | #6 |
yea chief i saw that too, i guess the previous owners just never took them off when teh switched to leaf springs whatever lol im in the middle of pressure washing it and wire brushing it then i got some rubber undercoating for it
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
03-05-2008, 01:27 AM | #7 |
got some more pictures
03-05-2008, 05:18 AM | #8 |
cool.....can we see them too???
CHEVY ONLY |
03-05-2008, 08:10 AM | #9 |
haha i know right it wouldnt let me upload them earlier oops
03-05-2008, 08:12 AM | #10 |
ill have the rest of the painted frame and completed cab corners tomorrow hopefully, and i cant figure out how to downsize my other pictures
03-01-2015, 02:27 PM | #11 |
so no posts for a long time, finished the truck, swapped the th350 out for a 700r4, rebuit the 400, making it a 406 with .480 ish lift cam and flat tops, several thousand hard miles later the 406 broke the crank started knocking, the truck was still my dd at the time so bought the 260hp/350 ft.lbs. gm crate, cleaned up the engine bay, rebuit the 12 bolt with eaton tru- trac and 4:11, drove a few thousand miles to and from work (hvac service), got a company truck, decided i wanted to swap to a LS motor as i had a 02 z28 t56 camaro in between there for 8 months or so to convince me the LS motor is the way of the future, did some craigslist searching found a 2006 gto 6.0/t56 with 74k in richmond that the guy wanted to part out (crazy i know), test drove it ran killer, lots of low end torque should be good for the truck im thinkin, so we worked out a deal($6500), i drove the car home pulled the motor, trans, ecu, radiator with fans, and the harness and he came and picked the car up, already have my wilwood 4 wheel discs, along with new painless harness and ididit steering column, truck is stripped frame is primed, now just waitin on the porterbuilt extreme front and rear treatment and air ride parts to arrive.....
09-29-2015, 11:22 PM | #12 |
really got some stuff done now that its starting to cool down a little, just waiting for the Vintage Air Front runner setup to come in and then its time for some thunder in the pipes
09-30-2015, 12:30 AM | #13 |
60-66 Nut
Looks good.
If you need a hydraulic clutch conversion to work that T56 let me know.
