1964 C10 Choke
The choke on my 1964 C-10 is very hard to pull. If I unhook the cable from the carb it slides freely so the cable is fine. The problem is an arm that rubs very hard on the choke cam. It rubs hard because the throttle return spring controls the pressure. What does this arm do? Is it really needed? It only seems to move the throttle a little bit when the choke comes on. I'm not sure this is the stock carb. I have a 250 straight 6.
Re: 1964 C10 Choke
using either foot press down on the accelerator pedal before pulling the choke knob
Re: 1964 C10 Choke
Thanks, I tried that but it didn't work. Pulling the lever away from the choke cam with my hand moves the throttle linkage, but moving the throttle linkage does not move the arm. Maybe something else is hooked up wrong.
Re: 1964 C10 Choke
Maybe take another pic of the linkage where it hooks to the carb.
Could be something easy to spot if we could see it. |
Re: 1964 C10 Choke
I put a lighter throttle return spring on and lubed everything now the choke moves ok.
Can anyone tell what model carb this is? If I needed to replace it, what model is best for a 250? thanks |
![]() Join Date: Oct 2012
Re: 1964 C10 Choke
From what I can see of it, it looks like a Rochester B, which would have likely been the stock carb in '64. A 250 was not a stock engine though, probably a 230.
Re: 1964 C10 Choke
x2 on the carb being a model B Rochester.
Many different variants....make sure to get the number off the base of the carb.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: 1964 C10 Choke
I had a 230 motor and had a 250 put in. I think they kept the carb. What carb is best for a 250?
Re: 1964 C10 Choke
I had a Crack in the hose from the valve cover to the manifold. That caused my poor idle problem so it looks like my carb is ok. Thanks
