![]() Join Date: Nov 2000
Kick panel speaker options
So my dash on my 65 c10 is already cut for a din size stereo. I'm tired of seeing the hole and would like some tunes. I was looking at the custom auto sound kick panel speaker housings but they're pricey. Has anyone used these or something similar with any kind of success? I've seen others that are less money. Do you just screw them in to the sheetmetal? Thanks.
![]() Join Date: Jan 2011
Re: Kick panel speaker options
My truck has the ones in it from LMC. They work OK.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Got these surface mounts from Crutchfield. Work and sound okay. Mounted on top of the sealed vents. Hugh |
I got the ones from LMC also and painted them to match the interior. They work with the vents and I used 3M two sided tape and a few sheet metal screws in discreet locations to hold them in place. They work fine but they do get a little bit in the way of the dimmer switch.
Thanks guys. Are the Lmc ones the same as the custom auto sound ones does anyone know?
![]() Join Date: Jun 2011
dont forget you can always install two 4in coaxial speakers in the center of the dash. plus it gives you great sound stage.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
Yes, plus custom auto-sound does sell in dash speakers. With that said what kind of sound can I expect from 150watt pioneer 6.5" speakers in the kick panels plus maybe the dash speaker?
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 09-28-2015 at 08:40 PM. Reason: fix |
Wow! What did you use to enclose those speakers? Looks pretty impressive. How does it sound?
its just foam cups with pillow stuffing and Fat Mat to encapsulate it. I have over $4,000 in the system and it sounds competition worthy. btw thank you
