Door Glass replacement
What is best way to get the old glass out of the channel to put in new glass?
![]() Join Date: Nov 2012
Re: Door Glass replacement
You have to remove the wing window assembly first. Then the window slides toward the front off the truck and you lift up and out.
Right, but i mean remove the actual glass from the metal channel at the bottom of the actual glass. Not remove the glass assembly from the door.
I laid my window glass flat on the workbench with the metal frame hanging off the workbench edge and slide the frame up to the edge and catch on the workbench edge. Then i took a wooden block and hammer and started tapping on one end of the glass until it broke loose and kept on tapping until it came out the frame. When i installed my new glass i just fill the frame up with black silicone , let it dry a few days and trimmed off the excess
![]() Join Date: May 2007
mine pulled apart by hand
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
