Old 09-17-2015, 02:18 PM   #276
chewychevy67
Re: 67 GMC super custom build
Now both my light and wiper nuts look the same. these look much better than what factory used.
chewychevy67 is offline   Reply With Quote
Old 09-17-2015, 11:54 PM   #277
chewychevy67
Originally Posted by geunther View Post
Great build, I have been through all the posts a couple of times now. I especially like the idea of using the transistorized ignition to retain the factory distributor look. I had one on a 72 LT-1 and never had a problem with it.
Several years ago the GM dealer that my brother worked at was throwing away a blue box test kit that had a logo on it for transistorized ignitions. I guess they hadn't used it for several years. Because of the LT-1, my brother grabbed it, which turned out to be the GM test kit for the ignitions. Luckily I held onto it for all these years as I might "borrow" your idea and install one on mine.
No too many people comment on the TI. Many probably don't know what it is. I could have gotten a pertronix kit but I thought this would be a nice touch. Thanks. I hope I don't have too much trouble getting it going once my engine is assembled.. I had a guy build this properly for my 327 engine. It sure wasn't cheap to have done but is cool to have.
Old 09-25-2015, 11:19 PM   #278
chewychevy67
here is where my window switches will be. the top one is vertical for the vent window and the bottom is horizontal for the door window. I wanted to put the bottom one where I have the marker but I could not because of motor location.
Old 09-26-2015, 08:08 AM   #279
Xeen
Xeen's Avatar
Standard practice in the auto industry is to group all the switches together, not to suggest that you should follow the industry, but why not put them right next to each other?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-26-2015, 09:49 AM   #280
chewychevy67
because the door window motor and vent motor are right beside the top switch in the door and the bottom has the window track right close and with the double switches on the driver side I would be tight if I could at all put them close together. these were literally my only options. these doors have no depth at all and the motors sit tight in there.
Old 09-28-2015, 08:51 AM   #281
Hart_Rod
Hart_Rod's Avatar
Truck looks great!
Hart_Rod is offline   Reply With Quote
Old 10-01-2015, 08:00 PM   #282
chewychevy67
Originally Posted by Xeen View Post
I gotta get me one of those twilight sentinels that's awesome, I also gotta get me a variable delay wiper switch which is equally as useful.
Well this got me thinking. So I ordered a wiper delay from member twouvakind and it arrived today. So I made a little modification. I am not sure if this is going to work yet as I have to find somewhere to test it. I don't want this mounted anywhere. It needs to look good and professional and somewhat like it could be original. I took a pointometer I had which I hope works that has a hole in the center (just like the sentinel) so the original wiper switch will be in the same place but the delay switch will rotate around it and thus no additional holes drilled. it will look identical to the headlight switch and bezel. Would be great if this could work.
Old 10-02-2015, 11:28 AM   #283
chewychevy67
I just tested it and it worked nicely. I'll post a video later today. This is how the switch will look.
Old 10-02-2015, 11:33 AM   #284
Xeen
Xeen's Avatar
Very nice, you gotta love modern comfort and convenience in a classic.
Next on the list, cruise control.
Old 10-02-2015, 11:39 AM   #285
chewychevy67
Cruise is done. I got a factory 68 set up.
Old 10-02-2015, 11:43 AM   #286
Xeen
Xeen's Avatar
I have an idea for the electric window switches, sending you a PM.
Old 10-02-2015, 04:20 PM   #287
notchbackgta
I bought one of those wiper delay modules too. I would be very interested if you can duplicate that switch setup for me. I haven't put mine in yet because I didn't know what I was going to to about putting in a second switch
notchbackgta is offline   Reply With Quote
Old 10-02-2015, 08:42 PM   #288
chewychevy67
I want to complete this switch first. I have one more switch just like it. If it turns out to my satisfaction I could make you one. I'll contact you when I have mine complete.
Old 10-03-2015, 06:46 PM   #289
notchbackgta
Cool, thanks
Old 10-04-2015, 05:44 PM   #290
chewychevy67
I got the switch finished up. Here is how it worked out. I have a few things I need to do by the wiper knob but you get the idea. you can turn the lever behind the wiper knob and that will turn on the wiper delay. the more you turn it the more delay you get. ill post a video tonight sometime.
Old 10-05-2015, 07:51 PM   #291
chewychevy67
Heres the video of the wipers. https://youtu.be/XfVXsbGdSzU
Old 10-05-2015, 08:17 PM   #292
Xeen
Xeen's Avatar
Very nice, well thought out and executed.
The infinitely variable delay is very cool.
Old 10-05-2015, 08:32 PM   #293
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work!
Old 10-05-2015, 09:24 PM   #294
chewychevy67
I thought about the switches and decided I am going to be happy with the switches the way they are. At some point my obsession to turn this truck into a caddilac has to stop if I ever want to drive it lol. I think I better start getting ready for motor and body work from here in.....
Old 10-06-2015, 12:23 AM   #295
Xeen
Xeen's Avatar
I hear ya, a lot of stuff can be bolted on after the truck is running and driving anyway.
Old 10-07-2015, 11:43 AM   #296
chewychevy67
I hated the way the original glove box lights on a/c trucks never illuminate the whole box so I had tried one from a Buick a while back but found that it just blinded you when you opened it. I found this lens in E-bay a while ago and thought that would be nicer even though it bumps out a bit. now it will shine to the back of the box and its nice as it is made white to the front so its not bright in your eyes when you open it. the light just sandwiches the cardboard so no modification to the cardboard is needed.
Old 10-07-2015, 05:23 PM   #297
chewychevy67
here are some renderings I had a member here do for me. This looks nice. here are the ones with a black roof...
Old 10-07-2015, 05:27 PM   #298
chewychevy67
and the white roof..
Old 10-07-2015, 05:42 PM   #299
Xeen
Xeen's Avatar
I think it looks stunning in all black, I never did like white on black and if you are going to paint the top a different color than the main body I don't think the top looks right without the two tone on the side as well.
That's just my personal preference though, I'm sure others will disagree.
Old 10-07-2015, 10:59 PM   #300
thelonerife
thelonerife's Avatar
I think your truck is going to be killer no matter what color it is. Its going to be one of the best.
thelonerife is offline   Reply With Quote
