Old 10-02-2015, 01:47 PM   #1
geoaoday
1970 C20 OEM wheel help
Gentlemen, I need your help. I am considering buying a 1970 C20 Custom 2WD truck. Currently the truck has some awful looking aluminum wheels with three different type tires. If purchased, I'd like to get back to the stock steel, eight lug wheels. My question(s) is this; are all eight lug wheel bolt patterns the same, say Ford and GM? In the future if this becomes my truck, I'd like to convert the front to disc brakes. Will the same wheels work for both disc and drum? I understand OEM wheels were 7.6 X 16, am I correct on that? Any help or direction you can give me is GREATLY appreciated.
Thank you.
Geo.
geoaoday is offline   Reply With Quote
Old 10-02-2015, 07:13 PM   #2
factorystock
factorystock's Avatar
Re: 1970 C20 OEM wheel help
This thread should answer all your questions.http://67-72chevytrucks.com/vboard/s...d.php?t=531286
factorystock is offline   Reply With Quote
Old 10-02-2015, 08:29 PM   #3
geoaoday
Factorystock, thank you, thank you thank you. The link you presented did in fact answer a lot of questions I hadn't even asked. I appreciate you taking the time to respond. Again, thank you.
Geo.
