Closed Thread
Old 10-03-2015, 10:25 AM   #1676
Clyde65
Clyde65's Avatar
Re: What did you do to your truck today part III
Finally got the bed back together. Washed and shined so dad and i went to a cruise in together.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 10-03-2015, 12:07 PM   #1677
DLW
Originally Posted by joesscamaro View Post
Sorry for the off topic question, but does DLW have a build thread going for his truck? I tried searching for one, but came up with nothing.
Hi Joe, I do not have a build thread unfortunately. I'm terrible about making a cohesive thread like that and keeping it up to date. But fill free to shoot me any questions..
DLW is offline
Old 10-03-2015, 02:33 PM   #1678
OldChevy61
OldChevy61's Avatar
Not to the truck but for the truck. Just drove through the monsoon we,re having to acquire a set of 15x8, 6 lug truck rally with rings and centers, all in great shape for 125.00. Gotta get them deals when you can,lol.
OldChevy61 is offline
Old 10-03-2015, 02:56 PM   #1679
Cleaned up the ole Mule for Cruising the Coast. We are now ready to spend the next 8 days in Hot Rod heaven!
Now to finish around the house chores so I can goof off for 8 days
Palf70Step is offline
Old 10-03-2015, 04:25 PM   #1680
Grizz1963
Grizz1963's Avatar
Bed off
Cab off
Battery relocated
Chassis and cab floor cleaned and painted with rust converter.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 10-03-2015, 05:12 PM   #1681
You been VERY busy Rian!
Old 10-03-2015, 09:23 PM   #1682
scuderia
scuderia's Avatar
Well with El Nino coming thought it best I deal with my drip rail. It'll take a while for the new paint to fade in but otherwise came out pretty good.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 10-04-2015, 08:53 AM   #1683
LDO
LDO's Avatar
Made a little progress on my motor...
LDO is offline
Old 10-04-2015, 09:37 AM   #1684
rickoner
Looks nice. Mind sharing what product you used? Also, any tips or tricks for sealing the gutters? I'm going to be attempting mine soon too.
rickoner is offline
Old 10-04-2015, 10:02 AM   #1685
joesscamaro
That's ok, I understand. That's why I don't have one going for my truck also! I will definitely be shooting some questions your way regarding the motor/electrical set up of your truck. Thanks!
joesscamaro is offline
Old 10-04-2015, 11:48 AM   #1686
scuderia
scuderia's Avatar
I used Fusor 122EZ bought both the sealer and gun from these guys https://www.blendsupply.com/lord-fus...ealer-10-1-oz/ .
One cartridge kit was enough but I was stressed the whole time thinking I was going to run out. Ended up with about 1/5th left.
Hardest part was trying to do the whole thing in one continuous run. You really need to do a dry run first figuring out how you are going to reach everything. Also the two downward slopes at the rear are a little tricky as the stuff flows quite a bit and I ended up with more at the bottom than anywhere else so plan for that. All and all a pretty easy product to work with.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 10-04-2015, 12:10 PM   #1687
Grizz1963
Grizz1963's Avatar
Just a bit.
Problem is, the way I had the cab stood up, I could not get it back in the garage, and the chassis and floor needed to be finished before I head for Clem's parrty.
The rest of this week has rain forecast, and once I get my new cab mount rubber set and fit it, the cab will be bolted in place.
So it all had to be done.
Just waiting for Martin now to give me a hand rolling it forward again, safely, and replacing the bed, then pack away and have a long hot bath.
Old 10-04-2015, 04:20 PM   #1688
Grizz1963
Grizz1963's Avatar
Woke at Stupid-O-Clock and had a mug of tea.
Very happy with the outcome so far.
All the cleaning and preparation paying off, it does take up the majority of the time but if you do, the result will not come back later to bite you in the bum.
Floor was seam sealed inside and outside on joins and all welds.
Underseal brushed on, I have also got spray on Schultz underseal but prefer. Getting into corners and around the back of folds.
Altogether now.......
At about 5.30 Martin popped over to help me get the cab down and move the bed into the back of the garage.
He seemed happy with the progress and result, he has a super critical eye.
So this is where my weekend ended, during the week I will paint the inner floor as I had done a second coat of seam sealer as well.
Tired tonight, but happy.
Old 10-04-2015, 05:40 PM   #1689
The Rocknrod
Moderator
The Rocknrod's Avatar
Mocked up my small block and 2004R transmission. I have more room with that trans than with the TH350 (small hump cab) Go figure. Using the POL engine brackets and trans cross member from western chassis.
The Rocknrod is offline
Old 10-04-2015, 09:27 PM   #1690
Cruising the Coast started today, so it's 8 days of classic rides. Started out cloudy and cool but got nice after lunch. Supposed to be mid60s to low 80s and clear all week. here is a sample of the 1400 shots I took today.
https://picasaweb.google.com/1060546...eat=directlink
Old 10-04-2015, 10:25 PM   #1691
akaupp
Put a Summit 1103 cam along with new lifters and double roller timing set in the beater.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline
Old 10-05-2015, 12:07 AM   #1692
mjh1965
mjh1965's Avatar
There is some very nice cars and trucks there . Thanks for sharing Bill . Enjoy your week of drooling
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 10-05-2015, 11:19 AM   #1693
verdell
verdell's Avatar
I get off work tomorrow at noon and we're headed on down. Man, I can hardly wait!
verdell is offline
Old 10-05-2015, 12:22 PM   #1694
Dee27xpress
Front Clip coming together.
Dee27xpress is offline
Old 10-05-2015, 02:06 PM   #1695
dwcardfan
dwcardfan's Avatar
Mounted the hood!!!!
dwcardfan is offline
Old 10-05-2015, 02:55 PM   #1696
TJ's Chevy
TJ's Chevy's Avatar
Installed me new mirrors on Crustine. Old ones tended to sit where ever they wanted to. lol
TJ's Chevy is offline
Old 10-05-2015, 04:51 PM   #1697
Chevy Fleetside
Chevy Fleetside's Avatar
I changed my white shocks with black ones.. It seems I had gas shocks in the truck but the left one went down but didn't rebound back. Maybe there won't be a lot of bouncing up and down anymore.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 10-05-2015, 05:03 PM   #1698
Grizz1963
Grizz1963's Avatar
It's amazing how much work you can squeeze into an hour when you,know your wife will be home soon and you spent the last two days in the garage.....
So tonight I pulled the truck out after work and "quickly" painted the floor, then cooked dinner..... Fried pork chops, butter and herb mushrooms and cous cous. Perfect.
First coat down, next coat in a few days, the sound deadening, felt pads and carpet once the paint is done.
Nothing else to do right now except start cleaning up the rear suspension, chassis and various other bits like brakes etc.
Old 10-06-2015, 12:03 AM   #1699
akaupp
Looking good. If you need a hand, let me know. I'm not far from you.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline
Old 10-06-2015, 07:40 AM   #1700
robber grin
Dang Griz - YUM!
truck looks great too!!
Stuffed my Driver's Door with glass and mechanicals - visor and peep were just begging me so why not...
robber grin is offline
Closed Thread
