05-28-2015, 07:55 PM | #26 |
Re: ECE Front Sway Bar Fitting Issues 71 C10
Still looks wrong. Return it and try elsewhere.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-28-2015, 08:00 PM | #27 |
That's the issue, shipping it back to them is going to cost more than i paid for the bar!
I agree it looks wrong to, i have the correct year truck, i am fitting it correctly, but still it is not working.
1971 C10 Short Bed Fleet Side 1990 Ferrari 348TB 2005 Ferrari F430 Too many 2 Stroke Motorcycles To List ! |
07-14-2015, 11:01 AM | #28 |
Sorry i just seen where you had posted on my thread.
Did you get this resolved?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
07-15-2015, 10:46 AM | #29 | |
ECE said there new stock that had in was they same as they sent me but could not provide me with a photo or a drawing to compare with what they have sent me. I have moved on to the rear suspension as i have sort of stalled on the front end because of the problem. How did you get on with yours ?
07-15-2015, 11:12 AM | #30 |
Never Ending Projects
One thing I am noticing in those two pics is your A-arms don't have as much vertical area on the front of the arm and kind of rolls up to the flat area on top. If you look at the ECE pic, it has a much larger area that has a squared rolled edge. Looking at things now, my guess is the bottom part of the bushing is not sitting flush to the arm all the way around. This extra space under the bushing is allowing it to rock and push itself out.
Definitely the arms are not made the same a stock.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-15-2015, 11:16 AM | #31 |
Just went and looked at my bar and yours appears to be missing a bend. That would explain why mine comes 3" off the ground and yours does not. Yours seems to go into the bushing at the wrong angle.
07-15-2015, 11:19 AM | #32 | |
07-15-2015, 11:31 AM | #33 | |
Is your arm a ECE one ?
07-15-2015, 01:53 PM | #34 |
http://67-72chevytrucks.com/vboard/s...=656258&page=2
Look at post #36. This is how it needs to be installed.
10-03-2015, 05:27 AM | #35 |
I had a thought yesterday while cursing out my electronic fan controller.
What if you did the caster mod? Or is that built into your control arms? If your arms are not stock that might be why stock sway bars do not fit.
10-03-2015, 04:02 PM | #36 | |
Not sure what the caster mod is ? The arms are stock replacement arms from CCP as someone had welded the bushes into my old ones, i stupidly put them in the bin when the new ones arrived so could not compare them. I have made some angled spacers to do 2 things,
Here is the spacers I have fitted them and it has fixed the problem
10-03-2015, 08:17 PM | #37 |
That's fancy.
Here's the mod= http://67-72chevytrucks.com/vboard/s...ght=caster+mod
