Old 10-03-2015, 09:58 PM   #22
bowtiebutler956
bowtiebutler956's Avatar
Re: First start of my 84 C10 383 in over 5 years.
Originally Posted by n8in8or View Post
Looking good Matt! Did you paint the trans or just manage to get it that clean?
Once I get my trannys clean, I give them a coat of cast coat aluminum paint Nate. While I could bead blast the case, I won't chance in on a trans. Thanks
Matt
1984 C10 long bed. Built 383, Lunati VooDoo flat tappet 233/241*(.050) 504/525 lift, Brodix IK200 heads, Edelbrock RPM air gap, Holley 750 DP. 700R4 Trans, with shift kit, and 3000 stall. 3.42 gears.
1993 K2500 ext/LB, 4x4. 3.42's, 4L80E, 6.5 TD, Holset Turbo, Intercooled, modified IP, 4" exhaust
bowtiebutler956 is offline   Reply With Quote
