01-19-2011, 08:14 PM | #1 |
Resident of Here
Post 60-66 Crew cab pics!
Post em up!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-20-2011, 12:08 AM | #2 |
Re: Post 60-66 Crew cab pics!
heres a few i got saved, not mine but lets see more pics of em if theyre members... think there was an earlier thread on same topic but couldnt find it
01-20-2011, 11:09 AM | #3 |
1961 crewcab
I'll try to find the thread.. I posted a hundred or so on a guys thread a few months back.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-20-2011, 11:17 AM | #4 |
Here is my dad's
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-20-2011, 12:15 PM | #5 |
1962 C-10
From the files...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-20-2011, 12:31 PM | #6 |
1961 crewcab
ok here it is: I posted about 80% of my pics on this thread, then I got tired!
http://67-72chevytrucks.com/vboard/s...light=crew+cab
01-20-2011, 01:05 PM | #7 |
If I am not mistaken, aren't the rear doors from the 1960-1963 era trucks, since the windshied wrapped around --the doors did not extend as far forward and the angle of the windows is different. Is this the case or am I imagining this ? Kieth
01-20-2011, 01:49 PM | #8 |
Keith,
if your asking if the rear doors on the 64-66 crews are doors from a 60-63, the answer is no. the rear doors on all the crews 60-66 are basically custom made from the specific year of the truck, they start with door skins and build from there. This is how I surmised they were done from looking at my dad's truck and 1 1962 crew cab and a 65 crew also.
01-20-2011, 01:53 PM | #9 |
1961 crewcab
60-61 used a cut down 60-61 door, then in 62-66 they added a straight front post, however since there were many different coach companies, there were lots of variations.
the blue and white truck in post #2 is the most common style for 60-61, and the three trucks in post #5 are the most common style for 62-66.
01-20-2011, 01:56 PM | #10 |
Stagecoach is who made my dad's and imo you can tell they were hand made with the exception of the rear of the door. I wonder who made the crews without the exposed door hinges.
01-20-2011, 02:33 PM | #11 |
1961 crewcab
...well I was wrong on the 60-61's stage way looks to have had the straight post for the whole run-
here are some other flyers, the last pic has one with a longer rear door, but still the external hinge... somewhere I have a flyer for the internal hinge crew...
03-31-2012, 05:06 PM | #12 |
Here is my 64 3-door C20 Stageway-Armbruster rig. Though it is currently bagged in the rear, it actually sits 2" higher than this photoshop shot... It's been a slow build but the motor work is done and gettin ready for the trans and front end bags soon.....
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
04-08-2012, 09:15 AM | #13 |
hey guys what ever happened to the grn &white crew cab in pic 5 -middle _is it a real truck -does somebody actually own it ?has anybody seen it in person ? thanks mike
04-08-2012, 10:49 AM | #14 |
1966 Crew Cab & 4X4 Fanatic
Yes, this is a real truck I saw it at a Super Chevy Sunday car show held at Lou Grubb Chevrolet in Phoenix, Arizona in 1987. I talked to the owner about it a little. It had a fifth wheel hitch mounted in the bed and the owner said he built it to pull his fifth wheel all around Arizona. He had the door trim for the rear doors custom made as this was not available from the coach company's that built them. It was a very nice build with no corners cut. I have not seen this again, may some of the other Arizona members will chime in if they have seen it still running around Arizona.
04-08-2012, 11:41 AM | #15 | |
chevy only
CHEVY ONLY... Nothin Else ! |
04-08-2012, 02:20 PM | #16 |
Wow!! That was 25 years ago and I assume that the same owner still owns it? Did you happen to snap any pictures of it? Wish they had digital cameras back in 1987, I would have taken a bunch of pictures of it then. Does it still look the same as it does in the picure above?
04-08-2012, 02:22 PM | #17 |
04-08-2012, 02:48 PM | #18 |
4 wheel drive GMC crew with a 6?
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
04-08-2012, 02:51 PM | #19 |
04-08-2012, 10:56 PM | #20 |
i wish i could contact the guy ! im would like to ask him some questions about the truck ! an article a few yrs ago said he used a 80s crew cab frame for the build ? i have one and it looks like there is too much kick up /or kick downs to use the 80s frame ? anybody ever inspect the truck ,up close or know how to contavt the guy ? thanks mike -im hot to get my crew cab built!!
04-09-2012, 12:27 AM | #21 |
Well Toby....I was holdin my breath waitin for ya to move on it.
Definately my favorite new build. So unique....Custom brightwork around....BB Vee Six...4 way pull....more doors than a cheep hotel...and actually in great shape. So....more new pic's....are you done yet...? C'mon.....break-ups jes around the corner.... Congratulations... Did you have to spend all yer lunch money on her..? I have a trip to Gulkana Airport and the Copper River Valley planned for late Sept. I'm drivin so won't be coming thru Anchorage....But I'll go the extra few miles to meet ya and buy ya a barley pop if you are into some show and tell on your new CrewCab... We'll see how it all pans out....but again....congrats on buying the "2012 Truck with the Most Potential" for the site.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 Last edited by A.T. RockDriller; 04-09-2012 at 12:33 AM. |
12-22-2013, 04:47 PM | #22 |
Nice!!!!!
04-12-2014, 07:32 PM | #23 |
"Where were you in '62?"
1962 GMC RailRoad Rare Crew Cab Pick Up Truck
http://6066gmcclub.com/gmcguy/CrewCabs.html https://www.youtube.com/watch?v=WlXDmckXhvU 1962 GMC Airporter 6 door Suburban https://www.google.com/search?q=1962...w=1680&bih=913
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 07-23-2014 at 08:34 PM. |
04-12-2014, 08:23 PM | #24 |
Sweet crew cabs!!!! Makes me want one to!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-04-2015, 02:06 AM | #25 |
anyone lookin to sell a crewcab 64-66 chevy truck two or 4x4 please contact me by email or phone email booger_28570@yahoo.com or 252-725-0824
triple d |
