11-06-2014, 09:15 AM | #1 |
LS power steering pump question
I tried searching for the answer but couldn't find it. On my 2001 5.3 i was filling the power steering pump for the first time and it dumped fluid all over the floor. I felt behind the pump (to tight to see in there) and it feels like its missing a drain plug of sorts. Am i correct in this thought and does anyone know the size/pitch if so? Thanks for any need
11-06-2014, 09:51 AM | #2 |
Re: LS power steering pump question
chances are with that year and being 5.3 it is probably not hydroboost unless it was changed that only adds a second return line so it is not threaded. As far as I know there is only the pressure side and the return side.
The pressure side is a different thread than your original, did you do some swapping on fittings or lines to get it to hook up? If it "dumped" that is probably not the case.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-06-2014, 10:09 AM | #3 |
There are 2 (seems to be pressed into body of pump) lines that come off the pump so I assumed the lower one was pressure and the higher one was the return. I never noticed or even look for the threaded open port that the fluid dumped out of.
11-06-2014, 10:23 AM | #4 |
The threaded one on the back is the pressure line. Sounds like you have a hydroboost pump. You need to cap off the upper return fitting if not running hydroboost.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-06-2014, 11:03 AM | #5 |
that makes sense, thanks for the info gentlemen
11-06-2014, 11:22 AM | #6 |
yep it is non pressured so just block it off and you should be good to go.
10-05-2015, 06:13 PM | #7 | |
But Found Her 25yrs Later!
I bought a complete power steering and hydroboost system off a 77. I'm doing the Power Steering upgrade first, then Hydroboost later. So your post answers my question I was searching for. I'll just plug the top one off until I install the hydroboost. Thanks
