Driveshaft shortening
hello so i have a 72 c10, and i have a long bed with a 2 piece drive shaft, and I am converting it into a shortbed. i am also cutting the frame under the cab. so my question is, should i just remove the front piece of the two part drive shaft, and take it somewhere professional to have it shortened, or should i take out the entire driveshaft and get a shorter 1 piece drive shaft? thanks!
![]() Join Date: Feb 2004
Probably the same price either way. Your better off with a new one piece....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
The reason I say this is because my drive shaft shop won't reuse the tube .They only use the ends so they get a perfect, balanced bullet proof shaft.
Re: Driveshaft shortening
ohhh okay that's smart, i didn't know if they had a machine where they could easily just shorten the tube thing on it, thanks
the boat guy
You have to take both pieces, it balanced as an assembly.
Its pretty easy to shorten a shaft, I don't know why they would need to retube the shaft. Strip the shaft, cut the weld yoke out with a lathe, cut the tube, renstall the weld yoke, time, straighten, weld, reassemble and balance. I've done it a few hundred times.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#6 | |
so you're saying that a brand new shortbed 1 piece driveshaft would be about $300?
That's what they run here. they use your yoak and ends only everything else is new
oh, i might do that then, that's way less expensive than what i was expecting
![]() Join Date: Nov 2014
I had my two piece shaft shortened, a new rear u joint installed and balanced for $144.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
I converted my truck to a SWB.
I ended up buying a new 1 pc shaft online from Tatton Driveshaft. It was under $300 shipped. |
