Old 10-07-2015, 04:19 PM   #5
akart
Re: Bleeding front disc brakes '82 K20
Originally Posted by Shugalou View Post
Did you put crush washers - two of them on the bango bolts and torque them down tight - this could be an air leak problem. Did you replace the rubber lines at the same time?
I'm in the middle of my own entire brake system overhaul, I have ran into many issues...and I'm still not there yet.
New crush washers on banjos, did not replace hose, that's w/the next round. Will check torque, good idea, thanks, but I think I will try the Teflon tape on the threads.
akart is offline   Reply With Quote
