Old 08-13-2012, 05:01 PM   #1
DURG
DURG's Avatar
High hump versus low hump comparison
Low and high hump next to each other for comparison.
DURG is offline   Reply With Quote
Old 08-13-2012, 09:09 PM   #2
Blue666
Re: High hump versus low hump comparison
Thanks for the picture comparison, always wanted a side by side on this.
That's a heck of a coffee stain on the low hump!
Blue666 is offline   Reply With Quote
Old 08-13-2012, 11:17 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Is there also a bolt-in low-hump?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-13-2012, 11:20 PM   #4
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=491452
Old 10-06-2013, 06:07 PM   #5
LostMy65
LostMy65's Avatar
By looking at the pictures, I'm guessing the low hump floor mat won't work with the bolt-in low hump tunnel.
Old 10-07-2013, 02:08 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I've read long ago the low hump mat will fit either low hump floor. Bolt in or part of the floor the shape ends up the same. From what I've seen all high humps are bolt in. The low humps are a mix. I do know from experience (the hard way) the low hump mat is about 5-6" too narrow to cover a high hump floor.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-07-2013, 09:58 AM   #7
1963c-10
1963c-10's Avatar
My low hump is bolted in and my mat fits fine.
1964 Short bed trailer
Old 10-07-2015, 04:30 PM   #8
LostMy65
LostMy65's Avatar
I'm switching to a th350,
Are the bolt in low humps the same size floor wise as the high hump?
What I mean,
Can I remove my high hump and the low hump will fit right in and bolt to the same holes?
Old 10-07-2015, 05:57 PM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
What I mean,
everything will work, but you need the piece that goes between the low hump and the fire wall
in the picture of yours that piece has been cut up.
and in post # 4 you can see the 2 different firewall pieces that should be welded in and that the low, or high hump bolts to.
