Old 10-09-2015, 01:29 AM   #1
geardrvn
Re: 48 5 Window air ride driver
Hey, nice work man! Looks good! I have rectangle stainless exhaust tips too I was going to run through the running boards like yours. I was curious how you mounted them? I was thinking about mounting mine directly to the running board so it doesnt rattle. Love these trucks on the ground!
"50 GMC 5.3l Vortec/bagged"
http://67-72chevytrucks.com/vboard/s...d.php?t=683537
geardrvn is offline   Reply With Quote
Old 10-09-2015, 07:07 AM   #2
oldnslow
Old Guy
oldnslow's Avatar
I mounted the rectangular tips directly to the U shaped tunnel that I welded into the running board. I added a 10"-12" section of stainless "flex" to allow some movement so nothing cracks. There is about a 3/16" gap between the tip and the notch in the running board to allow some air movement for cooling, it didn't discolor the primer, hopefully won't hurt the paint either. I am going to Locktite the four 1/4 -20 bolts that hold the tips on as they loosened a couple times last year.
oldnslow is offline   Reply With Quote
Old 10-11-2015, 10:52 PM   #3
youngrodder
youngrodder's Avatar
Good idea about adding the flex piece. I learned the hard way after a cracked tailpipe mount, I went back and added a couple of flex joints.
Looks great
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-11-2015, 11:01 PM   #4
geardrvn
Awesome thanks! I made the u shape inserts and got my running boards cut this weekend. Hopefully get the exhaust on soon..
Old 03-27-2016, 07:56 PM   #5
Advanced Design
Advanced Design's Avatar
Your truck came out spectacular!
Would you have a picture of the U shaped tunnel? Planning to go this route with my build and any help is greatly appreciated!
Advanced Design is offline   Reply With Quote
