10-06-2015, 02:45 PM | #1 |
230 cui - what is missing here ?
What is the name of part that is missing from my valve cover ?
'72 C20 '50 Plymouth Special |
10-08-2015, 10:22 AM | #2 |
Re: 230 cui - what is missing here ?
Looks like it might possibly be a vent or drain for an oil bath air cleaner. I'm not to savvy on these straight sixes though so if someone else knows the answer, feel free to correct me.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* |
10-08-2015, 12:06 PM | #3 |
THe hose attaches to your air cleaner.
It supplies fresh filtered air to your motor, which mixes with the crankcase fumes and is pulled out of the motor with your pcv. |
10-08-2015, 09:52 PM | #4 |
The Older Generation
Are you talking about the rubber seal or "Grommet"? I see a faint arrow pointing toward that area. LockDoc
10-09-2015, 12:03 AM | #5 |
10-09-2015, 09:28 AM | #6 |
pcv valve and grommet should be at top back of valve cover. That's just the intake from the breather. Missing grommet and either a metal or plastic tube to slide hose on.
10-10-2015, 06:53 AM | #7 |
OK, so the valve cover grommet should be the right name, right ?
and what about a name for this plastic tube ?
10-10-2015, 10:05 AM | #8 |
my 69 I-6 has a metal tube going from that hole to the air cleaner base.
10-10-2015, 03:22 PM | #9 |
It seems i partially found what i need.
Grommet PN #3868832 is easy to find&purchase. Unfortunately Connector PN #3921983 is not available anywhere or i can't name it properly :-(
