Old 10-10-2015, 03:27 AM   #1
J1MMY
'73-'87 Spindle swap ball joints
Please can someone post up either the OE or moog part numbers for the ball joints needed to fit '73-'87 spindles onto '63 control arms?
I've scanned through the FAQ's and done a search but can't find this particular info.
'63 C10 Longbox fleetside
'94 C1500 Sierra ex-USAF beater
J1MMY is offline   Reply With Quote
Old 10-10-2015, 10:56 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: '73-'87 Spindle swap ball joints
http://www.earlyclassic.com/catalog.aspx Might be easier if you just bought the ECE spindles that work with your 63 ball joints. They have them in 2 1/2 in drop or stock.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-10-2015, 11:28 AM   #3
J1MMY
Thing is, I already have '73-'87 drop spindles so purchase expense notwithstanding the shipping costs to get them over here is money that could be spent on renewing other components.
Old 10-10-2015, 12:41 PM   #4
Chevy Fleetside
It is not just the ball joints you also have to get a tie rod end and then you need the adj sleeve also. One of the vendors might sell it and maybe even ECE dose. You just have to make some phone calls and tell them what you need. I believe the stock 73 to 87 ball joints is what you need. Go to a local parts store and buy one and see if it is the same size as your stock ones. The difference will be the stud size for the spindle.
Old 10-10-2015, 01:52 PM   #5
J1MMY
I have a whole clip from another '79 that I bought for parts and the steering parts are brand new on there. If all I need are 73-87 ball joints to press on to the 63 arms and everything else is parts from the donor then it's all good!
Old 10-10-2015, 05:10 PM   #6
Chevy Fleetside
Just use all the parts from the 79 front end. All the components in my truck came from a 75. Just have to redrill for the idler arm. Measure 14 times drill once. I am guessing you will put power steering in also.
Old 10-10-2015, 06:23 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, just use the whole 79 cross member - arms and all.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-10-2015, 07:11 PM   #8
Chevy Fleetside
You don't have to change the whole crossmember if you don't want to.
Old 10-11-2015, 04:40 AM   #9
J1MMY
I'd rather not do a complete clip swap if it's not necessary and I can use the required parts from the donor.
One thing I am unsure of is how much the spindle change will widen the track at the front. I need to bear this in mind for the change of rims.
Also, which flexi brake lines to use to match up the new hubs to the old hard lines.
Old 10-11-2015, 10:33 AM   #10
Chevy Fleetside
You will have to split the hard lines on the brakes and install a proportioning valve. If you have the whole 79 donor you can just take the valve out of that with the lines and they will match up on your truck.
The 79 control arms are 3/4" wider on each side. I used control arms from a 75 and bolted them up to my 65 cross member. I am running 8" rims with a 3 3/4 back space with 255/60/15 tires. The rear end is out of a 72 which is the same width as the front, with the same rims but with 275/60/15 tires.
There is plenty of room. I can take a better front picture and post them later.
Old 10-12-2015, 01:12 AM   #11
Captainfab
60-66 Nut
All you need are '73-'87 C10 ball joints. They will fit the '63-'70 control arms just fine. You could also just change the complete control arms and have the better rubber bushings. If you change your entire steering linkage to the '79 linkage, you won't need those special tie rod couplers. However you will need to drill holes to bolt up the later model idler arm.
I don't remember for sure on the width increase but I want to say it is 3/4" on each side?
Old 10-12-2015, 01:24 AM   #12
Sik5chevy
i am doing the same thing to my 65 and i used 75 spindles, 75 ball joints and i took the linkage from the 75 and just put new 1975 tie rods on it. I will have to mount it to the frame. ill probably be posting on here for some guidance when it comes time to mount the linkage or at least get a pic of someone elses sense i didnt do that prior to disassembly. good thing is i replaced and cleaned everything so hoping to finish next week end. i wanted to maintain 6 lug so i bought aftermarket 6 lug rotors. capt fab gave me guidance before i started mine
Sik5chevy is offline   Reply With Quote
Old 10-12-2015, 10:46 AM   #13
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Nope, the control arms are the same width from '63-'87. The 3/4" width difference is due to the disc brake spindles. They space the wheels out 3/4" more than drum brake spindles.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-12-2015, 11:53 AM   #14
russellrox
Awesome looking truck man, off topic but what amount of drop are you running on your truck, same stance I am looking for, I already have 3" drop springs in the rear, but unsure on the front, I have 1" drop springs for the 79 front end but it's not low enough, would 2.5" drop spindle and the 1" drop springs look good.
russellrox is offline   Reply With Quote
Old 10-12-2015, 07:03 PM   #15
Chevy Fleetside
Here are a few shots with the tires. with the wider front end. 8" rims with almost a 4" back space.
The front is lowered 3" and the rear 4". The front tires are 255/60/15 and the rear are 275/60/15.
Old 10-14-2015, 07:19 AM   #16
J1MMY
Thank you all for your input; Chevy Fleetside, those pics and the wheel specs are super helpful as my next question was going to be regarding rim/tyre combinations and how much people have lowered the truck once they have converted to the later disc setups. Looking at your truck (and damned fine it is too) I am hoping that a 6" wide rim with a conservative - width tyre will tuck in the arches. From what I have read looking through other posts, I am already 3" lower than stock (14" from wheel centre to centre of fender lip) so with drop spindles I'm going to be where I want it to be.
As a slight aside, has anyone had issues with wheel fitment? I.e hitting the control arms with the inside of the wheel tyre or caliber clearance? I trial fitted an 8.5x15" Weld on my '79 and it caught the caliper.
Old 04-06-2016, 08:09 AM   #17
top dog
Where can you get these special tie rod adjusters and why do you need them I'm going 63 /79 spindles ?
top dog is offline   Reply With Quote
Old 04-06-2016, 08:25 AM   #18
lolife99
67-72 parts collector,…
lolife99's Avatar
Because 63-70 tie rods are 5/8" diameter.
73-87 tie rods are 11/16" diameter.
(two different thread sizes,...)
CPP sells the tie rod adapters, along with QA-1, and www.performanceonline.com
Keith
Convert to disc brakes.
Old 04-06-2016, 10:47 PM   #19
stsalvage
Scrapper 1
stsalvage's Avatar
I was looking to swap out my 1968 long horn with disc brakes talked to a guy at CCP he said they make a spindle that will take the 3/4 ton Ball joint and hook up to all the tie roda with out swapping anything you can get it in the 2 inch drop or stock disc bakes on my 3/4 ton longhorn
Then i had a brain fart ?
i asked do they make a spindle that will take a 3/4 ton tall joint for 1/2 ton. He said yes.
Reason why to use 3/4 ton ball joints there stronger.That's why off road trucks like baha race truck use 3/4 to 1 ton ball joints on 1/2 ton race trucks cus they take a beating.
Any one of you ever brake a ball joint on the freeway or going Fast.Ya it really sucks and on lowered trucks it happens all the time
stsalvage is offline   Reply With Quote
Old 04-07-2016, 06:42 AM   #20
top dog
Thanks for the info managed to get the modified adjusters
Old 04-07-2016, 07:32 AM   #21
canadian_diesel1964
i did this swap as well...the only issue for me was the lower ball joints being a bit small...i bought oversized lowers and still had to tack them in...then i used the special tie rod couplers...if you go back in my posts you might get part numbers...
canadian_diesel1964 is offline   Reply With Quote
Old 04-07-2016, 07:34 AM   #22
canadian_diesel1964
http://67-72chevytrucks.com/vboard/s...d.php?t=674235
