Old 10-10-2015, 11:47 PM   #10
Free Candy Inside
Re: Air bag suspension parts sourcing and plubming
Here's another pic. I ran my compressors into water traps and then into the tank. On the top of both pics is a reducer and then my pressure switch. I have my compressors on relays and I wired mine up slightly different. I am running power all the time to the relay and then wired the negative/ground to the pressure switch. With the pressure switch being the ground it is less likely to burn up so I've read/bean told.
Hope this helps some. I'm also running a AVS switchbox. I originally made my own which worked well but the AVS 7 switch box is well worth the $85 off Amazon in my opinion.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
air bags, airbag, installation, plumbing
