Old 10-09-2015, 08:44 PM   #1
steveo3318
steveo3318's Avatar
Who does the best steering box rebuild?
I have done a ton of searching and most of everything I see says to get redheadsteeringgear to do it. I have a 67 manual steering box that has a ton of slop. I adjusted and its still bad and gets to tight in full lock turns so I know its gone to far. I hear to many horror stories of the parts stores rebuilds.
Anyone running a redhead rebuilt box? I am thinking about sending them mine.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 10-09-2015, 08:52 PM   #2
swamp rat
swamp rat's Avatar
Re: Who does the best steering box rebuild?
There has been a number of threads here with people saying Readhead steering gears are worth it, i wouldn't think twice about it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-09-2015, 08:56 PM   #3
Heavymetl
I've got a Redhead on my truck, and I can't say enough good things about it's performance. Worth every penny.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 10-09-2015, 08:59 PM   #4
steveo3318
steveo3318's Avatar
Did you buy a reman from them or send yours in. curious of turn around? I am sending mine in cause my truck is a Frankenstein and I have no idea whats in it.
Old 10-09-2015, 09:12 PM   #5
beerformeplz
I just installed a Redhead today, I purchased it due to the reviews I read online about them.
beerformeplz is offline   Reply With Quote
Old 10-09-2015, 09:39 PM   #6
jeffahart
jeffahart's Avatar
I used a redhead, nice little company to deal with.
White K20
jeffahart is offline   Reply With Quote
Old 10-09-2015, 10:33 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
So, I send them my steering box and I get back a gem? How much, approx.? They return it with a nice finish?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-09-2015, 11:21 PM   #8
BCOWANWHEELS
my 71 manuel box needs remaning bad. I,ve taken up the play 2 times and its back to tons of sloppy play and getting hard to steer at slow mph
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-09-2015, 11:32 PM   #9
REEDS 72
REEDS 72's Avatar
I bought a rebuilt one from Auto zone in 09 it has worked perfectly less money for it and guaranteed for life.
REEDS 72 is offline   Reply With Quote
Old 10-09-2015, 11:43 PM   #10
mixermike
mixermike's Avatar
Redhead gets my vote
mixermike is offline   Reply With Quote
Old 10-10-2015, 12:02 AM   #11
BCOWANWHEELS
yea I priced a reman box from oriellys , it was a a1 cardone unit, $168.00 exchange for a manuel box. p/s was 128.00 exh.
Old 10-10-2015, 02:00 AM   #12
leddzepp
Moderator
leddzepp's Avatar
Same here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-10-2015, 03:17 AM   #13
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Don't the Redhead Steering Boxes have quicker steering ration so tighter steering and less lock to lock turns?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-10-2015, 08:05 AM   #14
davischevy
davischevy's Avatar
The 1977-1979 parts store boxes (Cardone) have the closer ratio. They are physically the same. The only problem I have run into is the size of the input shaft seems to be a crap shoot. I had to put a new rag joint on the last one, but, that's probably not a bad idea any way.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-10-2015, 12:56 PM   #15
freak
I didn't look but it's probably a limited lifetime warranty. Same as a lot of their stuff. That means they'll replace it once at any time in it's life but then the warranty is done.
freak is offline   Reply With Quote
Old 10-10-2015, 01:28 PM   #16
steveo3318
steveo3318's Avatar
The redhead does not offer a quicker ratio for my manual steering box and they strongly advise against it as it would make steering at slower speeds much harder. They do offer it for our trucks with power steering though. I will be shipping mine out to them monday. Thanks guys for all the input.
Old 10-10-2015, 03:51 PM   #17
BCOWANWHEELS
interesting on the 77-79 quicker ratio, thanks
Old 10-10-2015, 07:02 PM   #18
davischevy
davischevy's Avatar
Any of the suggestions above will work fine.
I use these people when I have one rebuilt. http://www.powersteering.com/us/
other Larry
Old 10-10-2015, 10:41 PM   #19
Boog
laying low
Boog's Avatar
I've read good reviews for AGR sectors.
http://www.summitracing.com/parts/ag...del/c10-pickup
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-10-2015, 11:41 PM   #20
rattle69
rattle69's Avatar
+1 for redhead. Used them many times. I never had one redone by them though. It was always exchange for me.
70 lwb c-10
rattle69 is offline   Reply With Quote
Old 10-11-2015, 03:27 AM   #21
hdff
hdff's Avatar
I put a red head on my 71 and sent them my leaky one for the core. No problems so far they did not recommend the quick ratio for my power steering
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 10-11-2015, 09:38 AM   #22
Bigdav160
Bigdav160's Avatar
I just rebuild my own
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-17-2015, 09:15 AM   #23
steveo3318
steveo3318's Avatar
Well Redhead has my vote. Basically I ordered the wrong one tues called Wed. To make sure I was getting the right one. They said no and changed my order. Received it yesterday and all I can say is wow. I can't believe how bad my other was. Made me realize how unsafe it was. I rebuilt my complete front end a week before and this was the last piece to the puzzle. Everything is as tight as new now. I recommend redhead to anyone.
P.s. If you have a manual box that looks like their very first picture on their inventory page don't order it for your truck. It actually fits on the inside rail. Not the outside like our trucks even though it's identical minus the output would be upside down ��. Call them.
Old 10-17-2015, 10:58 AM   #24
Howitzer
+1 on the rebuild. Cost me $30 for a PS unit and some time on YouTube watching the videos. Pretty easy.
Howitzer is offline   Reply With Quote
