Old 09-28-2015, 07:27 PM   #476
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
In mocking up for the ps pump, I saw the old GMC V6 Motor mount perch needed to go.
Also, here is a pic of the micky-rig fix bracket for the clutch linkage my uncle welded to the frame back in 1984. :-) Nostalgia
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-28-2015, 08:00 PM   #477
rickywideglide
rickywideglide's Avatar
Re: Lost My 65
been reading your story, really cool you got it back,i sold mine 20 years ago a 66 stepside, with fleet tail lights and diamond plate in bed,thought it was mine for a second. was curious what paint your using
rickywideglide is offline   Reply With Quote
Old 09-28-2015, 10:21 PM   #478
LostMy65
LostMy65's Avatar
Re: Lost My 65
The paint on it when I bought it back was in pretty bad shape. I also have patch panels I need to do.
So, for now I'm doing redneck body repairs and painting over the existing paint using inexpensive oil-based enamel.
Eventually I'll go back panel by panel doing it right with SPI Black Epoxy Primer.
I'm still undecided what direction I'll go after that. I do know I don't want something pretty and expensive where I have to worry about every ding and/or scratch.
Old 09-30-2015, 09:53 PM   #479
rickywideglide
Re: Lost My 65
yea im still undecided whether to just do rustoleum or get epoxy primer, my truck wont be a show truck just a driver
Old 10-06-2015, 07:53 PM   #480
LostMy65
LostMy65's Avatar
Re: Lost My 65
Originally Posted by jonzcustomshop View Post
Why not just tap the hole?
also, not in a rush, but when/ if you get some time could you post a straight on pic from the rear showing the taillights, and then get me a couple measurements of where they sit? bed to the edge of the lens center, and upper body line to the top of the lens center would be perfect!
I am going to do a version of the fleet lens on my step fenders as well. ( I wish gm had done this on 60-66 in the first place)
I should have something for you no later than this weekend.
Old 10-09-2015, 09:44 PM   #481
LostMy65
LostMy65's Avatar
Re: Lost My 65
Digging in.
Getting that ol sm420 out so I can get the th350 in.
So excited to finally be doing this swap.
Old 10-10-2015, 12:59 AM   #482
LostMy65
LostMy65's Avatar
Re: Lost My 65
The th350 I have came from summit.
Here is a way I've been considering to mount the tail.
http://67-72chevytrucks.com/vboard/s...31#post4216931
Old 10-10-2015, 11:58 PM   #483
LostMy65
LostMy65's Avatar
Re: Lost My 65
I did check if I have the factory holes for the auto crossmember. Buried under 50+ years of grime.
Old 10-11-2015, 01:43 PM   #484
LostMy65
LostMy65's Avatar
Re: Lost My 65
...clip....
I was 19 when I did the fleetside lights. I just hacked them in there.
I do have some fleetside light buckets that I eventually will weld in there.
Old 10-11-2015, 03:54 PM   #485
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Lost My 65
thanks, that is perfect!
they look like you got them in the right spot.
this will help when I do mine, same as you are planning I am also going to use the fleetside taillight buckets.
Old 10-11-2015, 04:33 PM   #486
LostMy65
LostMy65's Avatar
Re: Lost My 65
Old 10-11-2015, 05:29 PM   #487
Re: Lost My 65
I like that look
Old 10-12-2015, 08:10 PM   #488
LostMy65
LostMy65's Avatar
Re: Lost My 65
Getting ready for the auto swap.
Pressure washed the frame.
Used my leaf blower to dry it off, then pulled it back into the barn.
Old 10-12-2015, 09:38 PM   #489
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Lost My 65
�� cool update
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 10-12-2015, 10:29 PM   #490
LostMy65
LostMy65's Avatar
Re: Lost My 65
It would be kinda neat if it is the 283 I rebuilt myself with a jcwhitney kit back in 85/86. That means my rebuild lasted until that ol guy that I bought it back from blew it up.
My earlier post on this:
Originally Posted by LostMy65 View Post
Kind of a discouraging discovery today.
Not too big a deal, just would of been nice if the ol fella who paid for a 327 would of got a 327,
instead of his mechanic selling him a rebuilt 283 and passing it off as a 327.
But there might be a chance his mechanic just rebuilt my 283 I put back in the truck when I sold it in 86/87
3896944 = 1965 - 67
You see, when my dad and first bought it, it had a 283 in it.
When I wrecked it, I put in a 327 out of a SS Impala, but also kept the 283 stored.
Just before I sold the truck in 86/87, I sold the 327 to a guy in Canby who said he wanted it for his Nova.
I rebuilt the 283 with a JCWhitney kit, and put it back in.
So, it just may be that same 283 I sold it with.
Old 10-12-2015, 10:44 PM   #491
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
What is the casting date on the block?
Projects..
440CID 2X4 Pontiac
Old 10-12-2015, 10:45 PM   #492
LostMy65
LostMy65's Avatar
Re: Lost My 65
Where would I find that?
Old 10-12-2015, 10:47 PM   #493
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
The other side of the block opposite the casting number. . A letter and 3 numbers
Projects..
440CID 2X4 Pontiac
Old 10-12-2015, 10:49 PM   #494
LostMy65
LostMy65's Avatar
Re: Lost My 65
Ok,
I'll check tomorrow.
Old 10-12-2015, 10:51 PM   #495
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
Letter is month.. then a 2 digit day.. then the year digit..
Example E216 would be May 21 66.. since the block is a 60s we know 6 is 66.. :-D
Projects..
440CID 2X4 Pontiac
Old 10-12-2015, 11:01 PM   #496
LostMy65
LostMy65's Avatar
Re: Lost My 65
I had to go look.
G76 perhaps?
Old 10-13-2015, 01:06 AM   #497
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
I confuse Pontiac info with chevy sometimes.
This is from a chevy site.
Casting Date*
Small block casting date is located on driver side rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails.
Casting Date Example: E038*- (E = Month, 03 = Day, 8 = Last digit of model year (1978)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
Projects..
440CID 2X4 Pontiac
Old 10-16-2015, 06:44 PM   #498
LostMy65
LostMy65's Avatar
Re: Lost My 65
Ready to cut out the bellhousing cross member.
Old 10-16-2015, 09:01 PM   #499
LostMy65
LostMy65's Avatar
Re: Lost My 65
Also got my Power Steering Box mounted.
Old 10-21-2015, 09:56 PM   #500
LostMy65
LostMy65's Avatar
Re: Lost My 65
I've been spending a lot of time in the 'Engine & Drivetrain" section of the forums. I don't know much about automatic transmissions. I bought a summit th350 from a local guy. Included was the flexplate and torque converter. As I started mocking things up, I noticed the flexplate he included wasn't going to work. Fortunately I still had the larger flexplate left over from the 79 donor I had from my 66 service truck build.
From my research in these forums I learned depending on which flexplate you needed, determined what starter you needed. Fortunately I had the correct starter also.
Next I started reading up on torque converters. I first checked to see if the torque converter he including would bolt up to my larger (14") flexplate. It did.
So now my only concern/question is what stall torque converter do I have.
I'm going to take my chances and see how it goes.
I've also been reading... related to the stall of the torque converter is my engine/cam. My engine has quite a lope to it, and it requires premium octane.
