Old 10-10-2015, 06:38 PM   #1
LeesTruk
PCM reflash question
I've had the pcm for my 5.3 reflashed with the usual "get it up and running" tune. Since that time, I've changed my cam and would like to take my truck to a tuner for some fine tuning. Can my pcm still be used or do I need to get another pcm from the boneyard and start from scratch? Thanks
Later...
Lee
LeesTruk is offline   Reply With Quote
Old 10-10-2015, 07:25 PM   #2
Tilt
Re: PCM reflash question
You can use the same one.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 10-11-2015, 12:42 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yep you can still use it. There are only a couple potential issues; if the ECM was tuned and locked, it will have be re-licensed via an additional credit.
If it was "hard-locked" (a little tougher to explain, but there is essentially a way to lock an ECM in a manner that it can't be reflashed because the original GM data is corrupted). This is suuuuper uncommon, and takes more than just an HPt box.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-11-2015, 04:57 PM   #4
LeesTruk
Thanks gentlemen
Lee
Old 10-12-2015, 09:08 AM   #5
homemade87
Just a recommendation . Find you a tuner that does dyno tuning . There is no way to get one fine tuned with out it . A street tune will get it running fair but no way of getting it where it needs to be with out a dyno . It will cost a few more dollars but worth it in the end . I could not believe the difference when I finally did mine .
homemade87 is offline   Reply With Quote
Old 10-12-2015, 12:27 PM   #6
LeesTruk
That's the intent, once the truck is running (very soon). Just wasn't sure if the basic mail order tune would prevent the dyno tune from happening
Lee
Old 10-13-2015, 12:34 AM   #7
GMC-YA68
GMC-YA68's Avatar
What are the cam specs? Stock convertor still? What do you have it in? Just curious is all...
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 10-13-2015, 04:06 AM   #8
LeesTruk
The cam is a BTR stage 1 cam (.527"/.535", 206*/212* @ .050, 114 lsa), torque converter is a Trailblazer unit w/2200 stall, 3:42 rear
This is what it's in;
The nose should be going back on this weekend, and I think it'll be ready for start up in the next couple of weeks
Later...
Lee
Old 10-13-2015, 07:29 AM   #9
homemade87
Lee
It is a rare case to see a pcm locked . If it is locked you need to oust who ever it is . There is no good reason to lock a pcm that you own and can no longer make adjustments . Tuners can take a hard hit to there reputation if they do this .
As for the exsiting tune in the pcm , it will not hender the new tuner at the dyno . Good choise to take it to the dyno . I waisted a lot of time and money before I took mine trying to get it dialed in .
By the way , Things are looking good .
Old 10-13-2015, 08:13 AM   #10
Rich84
Rich84's Avatar
I see you are in Ct. too. Where do you plan on bringing it for the tune?
What manifolds are those?
Love the truck..
Rich84 is offline   Reply With Quote
Old 10-13-2015, 11:11 AM   #11
LeesTruk
The exhaust manifolds are from a 5.3L Trailblazer/Buick Rainier (I'm guessing they're the same as the Trailblazer SS manifolds). They fit perfectly within the frame, with no mod's needed anywhere.
For the tune, I'm planning on going to Total Induction Tuning Solutions, in S. Windsor.
Yeah, I'm from CT. Not too far from you actually, maybe 25-30 minutes across I-84
Lee
Old 10-13-2015, 05:16 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by homemade87 View Post
It is a rare case to see a pcm locked . If it is locked you need to oust who ever it is . There is no good reason to lock a pcm that you own and can no longer make adjustments . .
Rare? Not at all, and especially not with "big brand" tunes. The reason to lock a tune isn't for the benefit of the customer, its protection for intellectual property of the tuner. While IP itself sparks debate, it is the reason the HPT included that feature.
This is to prevent people from copy-n-pasting professional tunes, or from posting their tunes to a place like the HPT forum. You own the PCM, but as defined by the HPT credit system, you are licensing that software. You do NOT own the right to decompile or make code changes to the software itself. Just the same, you are paying for the service of a tuner. Essentially, this ends up being much like the "can I share a game I bought with my friends" debate that exists in modern media.
If you were to buy a vehicle like a Nicky Camaro, they would use a stock GM PCM, but it will be locked. IIRC, places like AMS or Speed Inc do the same. There are exceptions with certain vehicles that use an open-source tuning system (EVO's for example). For late model Fords or Subaru's, the Cobb tuning device is very popular, but if you "flash" their tune onto your ECM, its locked until you return it to stock.
