95 GMC transmission pan/ fluid change
Anyone running this pan? Figure if I'm going to drop the pan and change the fluid and filter I should add a deep pan with a drain plug.
http://www.ebay.com/itm/STEEL-700R4-...ht_5086wt_1362 |
Re: 95 GMC transmission pan/ fluid change
Just make sure you check for clearance if your truck is 4x4. Also use Black RTV to seal it up, the regular gaskets tend to leak.
1972 3/4 Ton Cheyenne Super, 350ci 650 cfm Edelbrock 4bbl Performer AVS, Edelbrock Torquer intake manifold, Headman Longtube Headers to 2 1/2in cutouts to 3 inch flowmaster super 40's true dual. 4.10? Rear SM-465/205 transfer case. Now this one is busted!! http://s59.photobucket.com/albums/g2...k/1972 Pickup/1995 K1500 Silverado 5.7L 350 TBI with 1in swirl torque spacer, Flowtech shorty headers, 3 inch collectors to y pipe going to 3in highlfow cat converter, single offset passenger side outlet, full 3 inch setup from collectors. Edelbrock High Flow 255LPH/67GPH Fuel pump, adjustable fuel pressure regulator and gauge, running at about 18psi. 3.73 Rear 4L60-E 4 speed auto (Rebuilt)http://s59.photobucket.com/albums/g2...1995%20Pickup/ |
| Bookmarks |
