#12 | |
Re: Help- both turn signal indicators turn on when lights are on
The truck sat for 4 years, and the critters had fun with a few of the wires under the hood. Either way, when I disconnected the marker lamps the indicator lights in the dash turned off, so for the moment they are disconnected. Also, since you mentioned added voltage draw, I do have a lot of added exterior lights on the truck, but the majority of them are on separate toggle switches, and almost all of them are LED's, so the added draw would be nominal, at best. It is worth noting though that I don't recall ever having this issues with this prior to the truck sitting.
1972 3/4 Ton Cheyenne Super, 350ci 650 cfm Edelbrock 4bbl Performer AVS, Edelbrock Torquer intake manifold, Headman Longtube Headers to 2 1/2in cutouts to 3 inch flowmaster super 40's true dual. 4.10? Rear SM-465/205 transfer case. Now this one is busted!! http://s59.photobucket.com/albums/g2...k/1972 Pickup/1995 K1500 Silverado 5.7L 350 TBI with 1in swirl torque spacer, Flowtech shorty headers, 3 inch collectors to y pipe going to 3in highlfow cat converter, single offset passenger side outlet, full 3 inch setup from collectors. Edelbrock High Flow 255LPH/67GPH Fuel pump, adjustable fuel pressure regulator and gauge, running at about 18psi. 3.73 Rear 4L60-E 4 speed auto (Rebuilt)http://s59.photobucket.com/albums/g2...1995%20Pickup/ Last edited by JetForceF22; 10-12-2015 at 03:10 PM. |
| Bookmarks |
| Tags |
| 1995, backfeed, electrical issue, indicator, turn signals |
