10-03-2015, 06:01 PM | #1 |
dash brake light
I know we've beat this question to death....but...just did a break job on the rear. New shoes, drums cut, a couple new sections of lines, and two new wheel cylinders... dash light still on! What gives? Are any of sure the light has nothing to do with the parking brake? I know a handful of people have said no, but mine for sure does not work and the light won't go away.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
10-03-2015, 06:09 PM | #2 |
Re: dash brake light
Learn the proper way to bleed your brakes and the pop valve will return to the center and the light goes off// read the factory service manual to learn
10-03-2015, 06:15 PM | #3 |
The prop valve is the only thing hooked to the light. Parking brake has no light on these trucks.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
10-03-2015, 06:30 PM | #4 |
Believe me, the brakes were bled. There is not one bubble of air in those lines. I didn't think I needed to mention that I bled the brakes, isn't that common sense when doing a brake job? What's a pop valve anyway cdowns?
10-03-2015, 07:00 PM | #5 |
Bleeding the brakes and bleeding them properly are two differnt things if you've got the light on you did not do it right
10-03-2015, 07:58 PM | #6 |
The Older Generation
Mine was still on when I got the rear brakes finished and bled. Brakes felt good so I started driving it and within 20 or so miles it went out on its own.... LockDoc
10-03-2015, 09:13 PM | #7 |
I put probably 40 or so on it the next day, no luck. I'm going to rebleed them tomorrow, if that doesn't work. I'm pulling the bulb out!
10-03-2015, 09:34 PM | #8 |
sit in the seat stomp brake pedal hard as you can and light will go off
10-03-2015, 10:05 PM | #9 |
Moderator
X2. This will often recenter the pin, and the light will go out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-03-2015, 10:16 PM | #10 |
I've never heard that one before, but I'll give it a try!
10-03-2015, 10:24 PM | #11 | |
LockDoc
10-03-2015, 11:21 PM | #12 |
18 Till I Die
Yup worked for me. One good hard stomp.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
10-04-2015, 07:01 AM | #13 |
10-04-2015, 08:56 AM | #14 |
Well I'll bleed them again today, just to be sure, then I'll give it stomp and see what happens. Thanks guys
10-13-2015, 01:13 PM | #15 |
Just an update guys, bled the brakes and the light stayed on. Stomped the pedal and it stayed on. Figured I'd drive it and see what happened, bet I made it 500 yards and the light went off and stayed off
10-13-2015, 03:24 PM | #16 | ||
"I ain't nobody, dork."
"prop" valve = proportioning valve. Even though it was inadvertently called a "pop" valve earlier.
The proportioning valve is mounted just along side the master cylinder. Gary
