Old 10-14-2015, 09:02 AM   #1
Shugalou
Shugalou's Avatar
Re: Why - only one caliper works
Thanks Wilkin,
Yes it is possible that it could be the prop valve, but it is brand new from CPP.
Before I go that route though I'm really thinking if it's the rear brakes are so far out of adjustment...? I backed off the e brake and retightened but not sure if it's enough so here's what I plan on doing to make sure rear brakes are adjusted to see if I can get pedal.
I found a good pointer on how to adjust the rears while on a stand emulating the truck going in reverse.
http://lugnutz65chevystepside.weebly...ake-shoes.html
After I get to this than I'll make sure the ebrake is correct by tightening it
right up till I can't turn the wheels then back off a bit.
Any suggestions are always welcomed and I appreciate everyone's feedback...when people say brakes are a PITA now I know why.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 10-14-2015, 10:57 AM   #2
nonstop
Originally Posted by Shugalou View Post
Thanks Wilkin,
Yes it is possible that it could be the prop valve, but it is brand new fromCPP.
CPP had a bad batch of proportioning valves for a run. Went through it on a 1950 Chevy project. I googled it and learned about the run. It has since been fixed, but you could have one of the older ones.
nonstop is offline   Reply With Quote
