Old 10-03-2015, 09:37 PM   #1
BMERDOC
BMERDOC's Avatar
Pancakes!! Yumm!
Ok. Now that I have your attention. Who is currently sectioning or "pancaking" front crossmembers? I want one sectioned about 1.5" and for reasons beyond my control at the moment I can't do it myself. Sorry for lurring you in with tasty breakfast foods but I need a quick answer. 😎😈
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-05-2015, 10:06 AM   #2
BMERDOC
BMERDOC's Avatar
Re: Pancakes!! Yumm!
No one knows anyone?
Nick Carter
Old 10-05-2015, 10:37 AM   #3
pat english
pat english's Avatar
pm sent
pat english is offline   Reply With Quote
Old 10-05-2015, 10:41 AM   #4
michael bustamante
michael bustamante's Avatar
thanks.......now i want pancakes with real syrup :-l
1967custom
michael bustamante is offline   Reply With Quote
Old 10-12-2015, 08:41 PM   #5
pat english
Got it ready to go.
Old 10-13-2015, 07:40 AM   #6
biketopia
just curious, whats the purpose of this? Is it the same principle as a drop member?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-13-2015, 09:34 AM   #7
BMERDOC
BMERDOC's Avatar
Yeah. Kinda the same thing. Lowers the front a little more while raising the pivots of the lower control arms. It helps with some of the angles of the front suspension too.
Nick Carter
Old 10-13-2015, 10:57 AM   #8
michael bustamante
before you install it if you have access to a stock one you should take comparison pics
1967custom
Old 10-13-2015, 11:22 AM   #9
BMERDOC
BMERDOC's Avatar
What comparison pics would you like? Of the crossmember? The truck is already up in the air with the suspension off.
Nick Carter
Old 10-13-2015, 12:19 PM   #10
dell72
I'm curious too of what a stock one looks like next to the modified piece to understand where it was modified.
dell72 is offline   Reply With Quote
Old 10-13-2015, 01:10 PM   #11
67 cst swb
67 cst swb's Avatar
Pat English... PM sent
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 10-13-2015, 01:53 PM   #12
BMERDOC
BMERDOC's Avatar
Dell72, if you look at Pat's pics in post #5 you'll see the section that was taken out. You'll also notice the 1.5" section that had to be filled. 1.5" is a good amount of sectioning because you don't have to move all the steering gear up on the frame to match.
Nick Carter
Old 10-14-2015, 09:49 AM   #13
pat english
Got it.
