10-08-2015, 12:55 PM | #1 |
55.2 rear axle flip....what shocks?
I am installing a rear axle flip kit on our 55.2 and would like to see what others are using for shocks on their setup.
My next step is to weld the shock mounts to the axle and I want to make sure I'm putting them in the right place and put the socks at the right angle. Any help/pictures would be greatly appreciated. This is the flip kit I'm using. .. |
10-09-2015, 04:35 PM | #2 |
Re: 55.2 rear axle flip....what shocks?
I used a similar kit I got from a trailer shop here in Dallas for like $20 picked up for 2" wide springs.
I used my original lower shock mounts and original uppers also. I used a set of front shocks for the rear , had the stroke length needed. ACDelco 520300 http://www.rockauto.com/catalog/rafr...&parttype=7556 http://www.rockauto.com/catalog/more...nid=436&jpid=3 |
10-10-2015, 02:07 PM | #3 |
I had the wrong link to the specs for the shocks I used:
http://www.rockauto.com/catalog/more...nid=436&jpid=0 Also , If your mount is going to be on the axle you will probably need a shock with an even shorter stroke, might check out a 1972 C10 front shock: https://www.rockauto.com/catalog/mor...nid=474&jpid=1 Last edited by 1958Warrior; 10-10-2015 at 02:16 PM. |
10-10-2015, 04:45 PM | #4 | |
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
10-10-2015, 08:48 PM | #5 |
I'm pretty sure I got mine from cpp.
Is there any certain angle the shocks should be? If I use the stock upper mounting location how far outward should the lower mount be? I think most of the time I see the lower end of the shock outward of the upper, just wonder if there's a certain angle or if it makes a big difference. Last edited by mygirlz55; 10-10-2015 at 08:53 PM. |
10-11-2015, 01:45 AM | #6 |
10-14-2015, 06:50 PM | #7 |
i flipped the axle on my truk using the stock upper and lower mounts with monroe-matic 33086
typically the flip ''kits'' cost you $79 to $99 plus shipping i shopped a local trailer supply house and got away with about $29 in my flip kit i kept hitting the bump stops so i changed to a air shock equivalent how much c-notch are you doing? what rearend are you using?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-14-2015, 07:10 PM | #8 |
For my install I extend and compressed the front and rear suspension as far as I could which gave me a maximum and minimum length. Went to real parts store and found Rancho shocks that were within specs.
10-14-2015, 09:26 PM | #9 |
I used KYB rear Shocks for ford econoline van 1966 the cross reference also said they are used on some jeeps
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
10-14-2015, 10:44 PM | #10 | |
How much of an angle are your socks mounted? It seems that they need to be as close to vertical as possible? Thanks |
10-14-2015, 10:46 PM | #11 |
Just looked at your build Orrie and realized your socks are mounted outside of the frame.
10-14-2015, 11:41 PM | #12 |
Axles are 74 K10 with 74 stock mount location. I welded a 1/4" plate inside the frame as reinforcement. If you look closely you can see the tabs on the axle were I used the 59 location and geometry, I have kept it in case I need more support from air or coil overs when I start towing a trailer. Before I had air shocks because of my slide in camper. Fronts match the 74 geometry as well with fabricated upper brackets.
