![]() Join Date: Feb 2014
ls 2 wireing
I have a ls2 w/6l8e from 09 G8 looking for wire diagram and pin diagram trying to do my own thanks Doug
Re: ls 2 wireing
The Older Generation
Re: ls 2 wireing
I am pretty new to the LS stuff so I'm not sure if anything at this link will help you or not.... http://lt1swap.com/geniv_harness.htm LockDoc
meowMEOWmeowMEOW
Re: ls 2 wireing
Thats a great resource for wiring. I'd also suggest downloading a version of the GM Factory manuals for the donor. They are available online, however I can't link to them as they are technically copyright'd.
Before you get too far on the wiring tho, make sure you've made up your mind on the trans. The G8 auto's aren't as popular in swaps because of the goofy flange-thingy on the output. Its possible to use a variety of other trans, but it will affect your overal wiring picture. Just something to keep in the back of your mind if you haven't gotten that far yet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
Re: ls 2 wireing
#6 | |
Re: ls 2 wireing
![]() Join Date: Apr 2005
Re: ls 2 wireing
Have you tried the G8 forums or LS1tech.com?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: ls 2 wireing
Thanks for all the help have ben to all the places you all have recommend have most of it figured out, with lti swaps 2010 Camaro and sum printouts my sun got me from his work on the 09 g8 but where does the start wire from the ignition switch go ? the g8 has it going to the BCM not using the BCM I assumed it would go to the ECM but no one shows it Im also unclear on the speedometer wire coming from the TCM does it go to the ECM and thin to the speedometer ?
