Old 08-20-2010, 04:27 PM   #1
stilkikin
Rear main seal in 65 283
Just wondering how hard is it to change it on these engines. I've never messed with a SBC before. My seal is leaking pretty badly. I just got it running again today and I noticed after the test drive I have oil leaking rapidly from the bellhousing area. I've got to pull the tranny anyways to put the T5 in so I'm not to dissapointed, just wondering how much of a PITA it will be. I've read theres different types of seals too, anyone know what comes on this year motor?
stilkikin is offline   Reply With Quote
Old 08-20-2010, 09:15 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Rear main seal in 65 283
Earlier engines had the "rope" type seal. Yours has the neoprene or rubber type.
Here are some posts that should help you understand what’s involved. Also, when removing the upper half of the seal from the block, use either a brass punch or heavy copper wire, or something else that won’t scratch the channel. Also some recommend a very thin application of silicone sealer at the joint, others recommend Permatex, while some suggest no sealer at all. Too much sealer can interfere with proper torque, leading to engine bearing damage.
http://67-72chevytrucks.com/vboard/s...rear+main+seal
And post #9 on the following thread:
Old 08-20-2010, 09:42 PM   #3
jocko
jocko's Avatar
stilkikin,
having done this before - i.e. change JUST the seal w/o pullin the motor, it's a pretty friggin painful job if I recall - since that first time, I've used a catch pan until major rebuild time... BUT, there's a tool out there that will make it a little bit easier if you do it for just the seal (i.e. engine still in the truck and crank stays in) called a "sneaky pete".
I used one and I think it's the only way I ever got the darn thing out. If you're gonna yank the whole motor and remove the crank anyway - then disregard this post.
Here's some links to two of them -
Amazon.com: KD Tools (KDT492) Oil Seal... Amazon.com: KD Tools (KDT492) Oil Seal...http://www.sjdiscounttools.com/lis27000.html
Good luck. If you do it, I don't want to see a picture of the seal, I want to see a picture of your face when you're done!
OH YEAH - and I would like to echo markeb01's comment on extra sealer - I'm a firm believer in a blob of pure silicon at the corners to seal it up. I did it without it once, and it leaked like crazy. Now that will piss one right off.
Old 08-21-2010, 02:44 AM   #4
apachedaddy
apachedaddy's Avatar
All good stuff, but make sure you ask for an offset rear main seal when you go to get a new one. It puts the lip of the seal on a fresh part of the crank and less likely to leak. I found this one out the hard way.. Good luck and just take your time its not so bad...
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 08-21-2010, 03:36 AM   #5
fryer1979
Redneck Hillbilly
fryer1979's Avatar
It always takes me less time to pull the engine, drop the pan and crank than it does to replace it still in the car. But that's me and my experiences. The links Mark posted should help out a lot, and it certainly can be done with the motor still in. I've heard that "sneaky pete" tool is awesome and well worth the cash, but I've never used one.
Here is a link to a "upper rear main seal remover/installer" tool from summit. Looks like it could be helpful to you.
http://www.summitracing.com/parts/WMR-W84019/
fryer1979 is offline   Reply With Quote
Old 08-21-2010, 01:42 PM   #6
Bugeyev8
Bugeyev8's Avatar
just run it for a while, sometimes after sitting it takes a while to get the rope seal lubed and swelled up, the sneeky pete tool works great, I have done about 6 this way and it always works fine, just be sure to pack as much in as you can before trimming it, and make sure no threads get between the main cap and block, my old buddy that wasa GM tech in the 60s said never trim the rope at all, but I was never able to pack it all in no matter what he said, or could have been thing were a little more accurate in the mfg process back then
Bugeyev8 is offline   Reply With Quote
Old 10-18-2015, 07:03 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
stilkikin,
Amazon.com: KD Tools (KDT492) Oil Seal Remover/Installer: Home Improvement
Thank you
Is there a style or brand rear seal that's better than another?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-18-2015, 08:33 PM   #8
AcampoDave
AcampoDave's Avatar
When did Chevy start using the neoprane seal anyway?
AcampoDave is offline   Reply With Quote
Old 10-19-2015, 01:10 PM   #9
GRX
GRX's Avatar
Originally Posted by acampodave View Post
when did chevy start using the neoprane seal anyway?
1959
GRX is offline   Reply With Quote
