Old 10-19-2015, 04:02 PM   #1
Zhedding
Angry No 02 activity
Hello, I have a 1971 Chevy c10 pickup that I put a 5.3 in I used a psi-conversion harness with it and I have been driving it for a few months without issue, a few days ago I hit a pretty good pothole and since then it runs really bad and its not getting and signal from either 02 sensor I put new sensors on both sides yesterday and still hasn't corrected the issue and they are both reading at .45 volts on my scan tool? The codes I'm getting are p0134( 02 sensor circuit no activity defected bank 1 sensor 1) and p0154 (02 sensor circuit no activity detected bank 2 sensor 1).
Zhedding is offline   Reply With Quote
Old 10-19-2015, 06:47 PM   #2
clinebarger
Re: No 02 activity
What year 5.3L? .450 MV is "Threshold" Voltage, Thats what will read all the time if there is a open circuit in the Ground or Signal circuits, Both O2's having this issue would lead me to a Ground issue, A lot of the early LS engines have a Case Ground for the O2's, Later ones use the Low Reference bus it the PCM.
clinebarger is offline   Reply With Quote
Old 10-19-2015, 06:49 PM   #3
cableguy0
Re: No 02 activity
Im going to move this to the Ls section for you. I would personally be tracing wires especially any wires that are common to both sensors. Make sure all the harness connections are tight and double check grounds.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-20-2015, 10:11 AM   #4
Custom 68
Custom 68's Avatar
Re: No 02 activity
check all your fuses and also any wiring plugs that might have came loose.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-20-2015, 11:14 AM   #5
Hart_Rod
Hart_Rod's Avatar
Re: No 02 activity
Gotta be a ground. Did you clear the codes and see if they came back?
Hart_Rod is offline   Reply With Quote
Old 10-20-2015, 02:19 PM   #6
Zhedding
Re: No 02 activity
2004 and yes I've reset codes and getting same code I'm going to check the ground again tonight but with the psi harness there is only one ground.
Old 10-20-2015, 02:23 PM   #7
Zhedding
Re: No 02 activity
And what's weird is I'm only getting the rich white smoke on the passenger side.
Old 10-20-2015, 04:51 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: No 02 activity
White or gray?
White= coolant
Grey=fuel
Blue/black= oil
Pink&sparkels= you blew the flux capacitor. Common result of using those ebay sub-jigawatt power supplies.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-20-2015, 09:58 PM   #9
Zhedding
Re: No 02 activity
Grey its rich, gas is dripping from pipe
Old 11-05-2015, 01:01 AM   #10
Henney
Re: No 02 activity
Did you ever get this sorted out? I'm having a similar issue
Henney is offline   Reply With Quote
