Old 10-19-2015, 08:48 PM   #1
rmawyer
1970 C10 Seat Belt Replacement
I want to replace mismatched seat belts in my truck. Got new belts from Brother's. Do I need to remove bench seat? It seems straightforward but I'd be interested in any advice before I attempt the swap - thanks!
rmawyer is offline   Reply With Quote
Old 10-19-2015, 09:06 PM   #2
mikeshome
mikeshome's Avatar
Re: 1970 C10 Seat Belt Replacement
That would be the best,i changed one with the seat still in but it was hard on the knuckles.My seat came out easy,but that will depend on rust.
mikeshome is offline   Reply With Quote
Old 10-19-2015, 09:18 PM   #3
rmawyer
Thanks for responding - I like to learn from those who have been there before me.
Old 10-20-2015, 09:02 AM   #4
Craftsmen
I did mine with the seat out, just have some help on the removal so you dont scratch the rocker panel. Be aware that the seat frame has some pretty sharp edges.
1970 C10 SWB
Craftsmen is offline   Reply With Quote
Old 10-20-2015, 09:31 AM   #5
68gmsee
Active Member
68gmsee's Avatar
As above ^.. Best with seat out.
I've taken the bench seat out by myself by using piece of discarded carpet and also cardboard under it after removing the bolts to keep it from scratching floor board. A helper would be much easier, though.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-01-2015, 07:56 PM   #6
rmawyer
Thanks to all responders - I was able to replace them without taking the seat all the way out - I did have to unbolt the seat and move it toward dash.
