Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-20-2015, 12:46 PM   #10
PGSigns
PGSigns's Avatar
Re: help with newer top end combo
What ever you decide to do for a cam change the springs to a set matched for the cam shaft. Don't make any assumptions on the springs. You will need to know a lot more about your short block to figure out what to do with the heads. At the minimum the part number on the piston and the measurement of how far down in the hole they are. With that info and the CC's of the heads you can see what you have and if you can get where you want to go. If you decide to angle mill the heads to get the compression up you will need to also do the intake. Then these two stay together for ever. Then I would look at getting the heads flowed and picking a cam to work with what you have for heads. All this adds up quick to make what seems like a good deal work and can easily run more than a good set of new heads.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
