#526 |
Re: LS swappers, post up your pics!!
#527 |
I'm just glad to be here!
That is a loaded question without more details from you. I suggest checking out lt1swap.com. He has put a ton of info on modifying many different harnesses.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#528 |
Finally got my 04 Z06 ls6 installed in my 71 2wd blazer! Completely rebuilt (fairly stock), Kwik performance bracket system. Seems to be running well.....
#529 |
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
#530 |
My 1990 Jimmy redo. Sent it to a place in Vegas. Paid 16K and received the worst workmanship i have ever seen in my life. Note to self. Even if your to busy in the oil patch working....still...do it yourself.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
#531 |
if i have a complete 2004 gm truck is it hard to do the swap onto a 83 blazer im pretty handy just not sure i see a lot of you guys do it just thinking the wires look a little scary . and when i say 83 blazer its cause my frame is a 83 but my truck is a 69 so im kinda handy
just not sure what i need to take out of my 04 |
#532 |
ls1 from 04 gto. heads, cam, lt's
#533 |
Finally got my LS3 in for good (hopefully) in my 66'. Need to adjust the trans/engine angle a little but all fit nicely.
#534 |
Very nice!!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#535 |
#536 |
What kind of radiator did u use? I'm doing a 5.3, 4l60e swap in a 68 shortbed looking for all info I can get.
#537 | |
I also switched, from what you see in these pics ,which are the 2014 Camaro beltline water pump and balancer, to the corvette water pump (2004 vintage I believe) and balancer as it pushed the beltline back 1.5" closer to the engine. FYI, the 2010+ Camaro and truck beltlines are the same and also stick out the furthest compared to the F-body and Corvette beltlines. Just in case anyone is looking for a bit more room like I was. ![]() ![]() |
#538 |
![]() Join Date: Mar 2014
Got my motor painted and dressed out with the valley cover and intake. Will be putting coil pack and accessories on tomorrow
#539 |
What kind of other parts did u use if I may ask? Engine, drivetrain, anything is helpful. Thank you
#540 |
#541 |
Truck and auto performance nut
Looks great. Didn't see a build thread so....what IFS is that you have?
thanks!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#542 |
I'm usually on the 73-87 section but this is my first 67 c10 that I'm building.. here is my swap I'm doing on it..
#543 |
Here is one I did for a customer on his 88...
#544 |
Windy Corner of a Dirty Street
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#545 |
looks like a Level 1, mild dropmember from Porterbuilt.....
#546 |
My LS swap is dropping in today into my 1966 C10. Out with the old 6 cyl 250 for a new 5.3 v8 with 6L80E transmission!
#547 |
![]() Join Date: Apr 2005
nice!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#548 |
02 5.3/4L60 in my 1988 stepside.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
#549 |
#550 |
http://s1050.photobucket.com/user/jo...t9d4d.mp4.html
Little idle clip of my 5.3 with btr stage 4 224 230 cam fbody longtubes and hpipe |
