Speedo Cable - To Lube or Not to Lube
Just bought a new speedo cable for my 72 Burb. It is complete with both the inner metal cable and the outer sheath with the screw on connectors for the transmission and speedo. The inner cable appears dry. Should I lube it prior to installation? If yes, what should I use?
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
Yes lube it. I have always used a graphite spray, But I am sure a light weight lithium grease would work just fine. You do not want to use an oil or spray such as WD-40.
Good Luck, 70short/step ![]() |
20' Daredevil (Ret)
![]() Join Date: May 2003
Yup, what he said. I have used lithium grease on mine with no problem, but I understand it's not the best for very cold climates. In Arizona, you should be fine with either grease or graphite.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
72 LONGHORN OWNER
I just bought a new cable too and instructions said to lube.......checked in side box and it came with a small tube of lube...............
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
Yup, lube it.......that is unless you want to replace her again....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
speedo shop told me to use petromium jelly(vasoline) and nothing else
1961 Apache short step. |
72 LONGHORN OWNER
That's...........
Thanks guys. No lube came with the cable so I bought a tube of Permatex white lithium grease and coated the cable, then installed it.
Jeff
