Crew cab question...
There are no interior light switches on my rear doors. My truck is (was) a bonus cab, it did not come with rear seats, carpet, or seat belts. Is not having interior lights come one when you open the rear doors part of the bonus cab package?
Few things in life will make you look stupider than putting a dollar sign after a number. |
Re: Crew cab question...
im sure it was wouldnt be hard to add them really if you to interior out.
#3 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
What trim level is yours?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
^^i belive your right, trim level
my crew is a c. deluxe, has the holes for them, but does'nt have them, nor is there any wires from the int. harness any where for them |
Mine is a Silverado.
Does it have YE9 Silverado option?
UF2 -Cargo lamp C91 - Dome light.
No C91. But it does have a dome light and a cargo light, but no switches to turn the lights on when you open the rear doors.
My 90 is a silverado. Full load with the exception of vinyl seats (weird). It has a dome and cargo light with the switch above the drivers shoulder. No door switches for the interior light for the rear doors.
Addicted to Rust
![]() Join Date: Dec 2009
My 87 GMC is a highline truck AC, PW PL Carpet etc and no rear courtesy light switches.
Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Yeah, mines a fully loaded Silverado too, except for the whole no back seat thing.
I am sure you know this but the missing back seat is because it was a Bonus Cab.
My 1991 Cheyenne R3500 doesn't have rear light switches either.. BTW, I was bored and stuck on a con call so here is your RPO list: AU3 Power Lock - Side Door A01 Window - Tinted, All Shaded Windshield A31 Window - Side, Power A52 Seat - Front Bench BB5 Ornamentation BC3 PANEL,INSTR(DLX) BS4 INSULATION,CAB BK PNL B30 Floor Carpet B32 Floor Mats - Front B85 Extra Molding - Belt Reveal B96 Extra Molding - Wheel Opening CMD ASSEMBLY PLANT - FLINT, MICHIGAN C6W 9200 Lbs. GVW Rating C60 Air Conditioning - Front Manual Controls D2C GEAR SPEEDO DRIVEN D34 Mirror - Visor Vanity D45 Mirror - Outside, SST E3R – no idea E6J –no idea E63 Pickup Box - Fleetside (Wideside) E9Z KEY SPEEDO – DELETE GQ1 Rear Axle - Base Ratio GT4 Rear Axle - 3.73 Ratio G60 Spring - Rear Auxiliary G80 Axle - Rear, Limited Slip JB8 BRAKE POWER, DISC/DRUM, 10,000 LBS K22 Generator - 94 Amp K34 Cruise Control L19 Engine - 7.4L V8 TBI MX1 3 speed automatic M40 Transmission - Auto, 3 Speed, Torque Conv. Var. 1 NA5 Emission System - Federal Requirements N31 Steering Wheel – Custom N33 Steering Column - Tilt P10 Carrier - Spare Tire R04 WHEEL SINGLE RR SSL ORNAMENTATION EXTR, NAMEPLATE, GMC SIERRA SL TR9 Lamp Group TT4 Headlamps - Halogen, Pencil Beam UF2 Lamp - Cargo UM6 Radio - AM/FM Stereo, Seek/Scan, Cassette, Clock UN9 Radio Suppression Package UP8 RADIO PROVISIONS, AM/FM STEREO, INSTRUMENTATION U73 Fixed Mast Antenna VXS Vehicle Complete V02 Radiator - Heavy Duty w/Trans. Oil Cooler V22 Radiator Grille - Chrome V73 ANTENNA, FIXED XYN LT235/85R16E R/PE ST TL ALS BL – Front X88 Conversion Name Plate Chevrolet YD3 Front Axle For Scheduling GVW Plate YE9 Equipment Package, Level 3, Silverado/Sierra Classic YG3 MOLDING,BODY SI & WHL OPG(BRI) YG4 Optional Seats Not Desired YYN LT235/85R16E R/PE ST TL ALS BL – Rear ZN3 SPRING FRONT FOR SCHEDULING GVW PLATE ZQ2 Power Door Locks (AU3) and Power Windows (A31) ZQ3 Convenience Package, Tilt-Wheel and cruise control ZYN LT235/85R16E R/PE ST TL ALS BL – Spare ZY1 Color Combination - Solid 24D TRIM COMBINATION CLOTH, DK BLUE (D) (91) 24I INTERIOR TRIM DK BLUE (I) (94) 42U PRIMARY COLOR EXTERIOR (don’t know what yours is..but guessing Midnight Blue Metallic)
I currently have 4 crew cabs sitting at my house
1 1988 2 1989's 1 1991 None of them have the switches on the rear doors, and one 89 has a cargo light. My crew cab short bed didn't have them either, I added them though. Pretty easy, most auto parts stores carry the switches and you just need a single wire to each switch. The hardest part is running the wires.
I've been following this thread with some interest as I have a 1980 Suburban Silverado which does not have rear door switches.
I was out and about today hitting local junk yards, so I made it a point to look for any crew cabs and suburbans to see if any of them had switches. I didn't keep an accurate track as far as years, but we have a wide variety of rigs sitting in two yards, and I checked 8 suburbans and one crew and none of them had rear door interior light switches. Unless somebody here chimes in and says their all-original one-owner survivor rig has rear door switches, I'm going to assume GM just didn't think they were necessary.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
I had an 89 parts burb that had rear door light switches. It appeared to be factory wiring...
#15 |
78K & 79C Jimmys
can't remember the 78 burb,but the 87,88,89 had rear switches
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#16 |
The 2 Suburbans I have owned 1978 and 1990 that I still have has rear switches. This may be limited to Crew Cabs. I have see one with them though, but who knows if it was a Suburban switch.
#17 |
my 88 crewcab has no rear switches.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#18 |
that was irritating for me with my 87 r30 3+3 didn't have the switches open the back door and nothing it really sucks when you got kids putting them in there seat after its dark out. but my 88 v3500 bonus cab has them and it has a cargo light but its also a classy chassis hard telling what they added without looking at rpo's
just wonted to mention some bonus cabs had a tool box option to fill the empty space in the rear where a bench seat would be in a 3+3. i can see average Joe working 9 to 5 construction wouldn't need a dome light it would just run the battery down
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
