Old 10-23-2015, 06:13 PM   #1
68c10owner
68c10owner's Avatar
TH350 1 pc driveshaft question
I currently have a 700R4 in my truck that is on its last leg. A buddy has a TH350 I can pick up cheap. Last time i did this I used the driveshaft out of my 65 chevelle but never measured it and that car is long gone. Does anyone have the measurement?
BTW, before anyone asks why I`m going to a th350, its only temporary. This is my only vehicle so I need to put the th350 in while I have the 700r4 rebuilt then swap back. A lot of work yes, but since its my daily I have to do what I have to to get by.
Anthony
68c10owner is offline   Reply With Quote
Old 10-23-2015, 08:34 PM   #2
Project86
Re: TH350 1 pc driveshaft question
If you have a short tail th350 and it should be fine using your original driveshaft if I remember correctly. If you go from a long tail to a short it won't work. But i could be wrong...I read it somewhere just would have to search the forums again
Project86 is offline   Reply With Quote
Old 10-23-2015, 08:36 PM   #3
68c10owner
68c10owner's Avatar
Th 350 and 700r4 are different lengths so I don't see how the driveshaft would be the same length for both transmissions.
Anthony
Old 10-24-2015, 05:05 AM   #4
Project86
Just found my source. If you have a long tail th350 you can use the original driveshaft on the 700r4
Old 10-24-2015, 09:52 AM   #5
Chaplain
Chaplain's Avatar
Yep...me too on the swap and me too on using the same driveshaft. However, I'm staying with the 350.
Chaplain is offline   Reply With Quote
Old 10-24-2015, 10:05 AM   #6
Project86
Good deal. My 292nd gear in my th350 went out so I may go with the 700r4 here soon
Old 10-24-2015, 11:14 AM   #7
Axle
Axle's Avatar
When I did my 700r4 to th350 swap I used a long tailshaft (9-1/4") th350 and my original one piece driveshaft. You can figure out the difference when you get your donor th350 and measure its tailshaft.
Alex.
Axle is offline   Reply With Quote
Old 10-24-2015, 02:31 PM   #8
68c10owner
68c10owner's Avatar
Thanks for the input guys. Helpfull info. I'm not sure what tail shafts it is but I'm guessing it's a short shaft. I haven't looked at it yet. I need to have everything ready to go before I do the swap because this is my only vehicle and I won't be able to have any down time. I can do the swap in less than a day so it's a weekend project.
Anthony
Old 10-24-2015, 02:32 PM   #9
65standard
65standard's Avatar
Center to center of u-joints is 55 1/4" on my 1985 C/10 with factory installed 350 trans. Note that my trans is a long tail.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 10-30-2015, 04:14 PM   #10
68c10owner
68c10owner's Avatar
So for a 6" short tail shaft I`m guessing I`d need a 58 1/4" shaft? My trans went out last night so I`ve got to get this swapped over the weekend and I cant find a trusted 700R4 anywhere. I just cant spend $500 on a used one and hope that it works. I know this Th350 works and its free.
Anthony
Old 10-31-2015, 09:27 AM   #11
65standard
65standard's Avatar
Sounds about right.
Old 10-31-2015, 05:47 PM   #12
68c10owner
68c10owner's Avatar
About to start the swap. I`m going to get the TH350 in there and then take a measurement. I did several searches and came up with several different measurements for the same 117" wheel base trucks. We`ll see how it goes.
Anthony
