Re: Automatic floor shifter ?
Haha tried to hide the f word. Ya totally forgot about the small hump not coming off. As long as you can get a wrench between the tranny and the bottom of the floor from underneath to tighten the bolts then it's pretty easy. 4 bolts hold it to the floor. Then just cut out a slit for the lever to go through the floor and connect the rod to the tranny. Pretty easy as long as you follow the instructions as far as the angles. They sale an adapter to use whatever you want as knob. So instead of the push bottom you just push down on your wolfhead. I have a beer tap in mine. So you can run anything.
