Old 10-24-2015, 07:52 PM   #1
jcblue
jcblue's Avatar
I know throttle cable end?? what I need, I just don't know what it's called..
The carpet and mat in my truck has restricted some of my throttle travel.. I'm wanting a "shim" of sorts between my pedal and end of the cable, so as to choke up on the cable and pull the peddle up off the carpet some. I'm just not sure what to look for.. Will attach pic
jcblue is offline   Reply With Quote
Old 10-24-2015, 07:55 PM   #2
jcblue
jcblue's Avatar
Re: I know throttle cable end?? what I need, I just don't know what it's called..
How much I want the peddle off the floor
Old 10-24-2015, 08:01 PM   #3
firedemon
I have never seen a spacer on the cable not that there isn't such a thing but I have seen an adjustable cable bracket on the engine that could move the cable back maybe summit or jegs
firedemon is offline   Reply With Quote
Old 10-24-2015, 08:16 PM   #4
chipflyer
chipflyer's Avatar
Cut the current clamp off and get a cable "knarp" at a bike shop.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 10-24-2015, 08:22 PM   #5
swamp rat
swamp rat's Avatar
I cut the end off of my cable and used an adjustable cable stop.
http://www.oreillyauto.com/site/c/se...0263/C0142.oap
Google it for more pictures. Pass the cable thru the holes on the side then screw it tight.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-24-2015, 08:26 PM   #6
chipflyer
chipflyer's Avatar
That is technically a knarp! Lot of hardware stores will have them too.
Old 10-24-2015, 09:08 PM   #7
Sklptrljay
Sklptrljay's Avatar
Go to the hardware store to the area where they have chain, rope, cable, etc....
They should have crimp-able connectors for small cable that will allow you to shorten yours up.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 10-24-2015, 09:15 PM   #8
Boog
laying low
Boog's Avatar
A fishing line split shot would be easy enough to use. No special tool needed. Or just bend the pedal end upward a little bit. Grab hold of the top end and pull up on the bottom end to bend it. Or remove it and put it in a vise to hold it while you bend it.
A knarp huh? I've never heard of that.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-24-2015, 09:42 PM   #9
swamp rat
swamp rat's Avatar
I was typing the reply and finding links when you posted..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
