10-24-2015, 07:15 AM | #1 |
Might be dumb question so be gentle
Should it have my truck tuned/dynoed ?
Just going to be daily driver..have a stock 5.3/4l60e, has base tune from lt1swap.com..seems to run fine other that the trans doesnt follow the engine when you step on it (if that makes sence) which i assume is more a trans issue. |
10-24-2015, 07:19 AM | #2 |
Re: Might be dumb question so be gentle
Transmission tuning is part of having a real tune done. Mail order tunes are good for getting it running....otherwise to be optimized you'll need more work on the dyno or the street.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
10-24-2015, 03:00 PM | #3 | |
meowMEOWmeowMEOW
I wouldn't waste time with just dyno'ing it, as the dyno is only a tool to confirm and test changes (and in some cases, theories). Getting a professional tune done in person, with both road and dyno time, is the "procedural" way to handle it. Were you to be building a 800hp road monster, this would become absolutely needed. In general stock swaps don't require the same level of detail, since very few things are changed from a factory calibration, however if your experiencing a problem related to the trans cal, a mailorder tune will just be guess-and-check'ing the results. By taking the truck to a pro tuner, the time on the road and/or dyno should be able to reproduce your problem and view it on a log. Then make the needed corrections based on the log and general driver preference. You may be able to find small gains in performance as well, since even bone stock motors have 5-20hp laying available in minute timing and fuel changes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-24-2015, 03:56 PM | #4 |
My lq9 6.0 basic just to get it running tune ran fine to, but at first made only 265 hp on the dyno..for some unknown reason they put in a base tune for a 4.8..when they got done with the final tune it was pulling 345 hp..so yep..worth every penny.
10-24-2015, 06:02 PM | #5 |
Thanks for the information I just wanted to make sure that I was wasting money with a tuner when my application does not warrant it but it sounds to me like it would be worth me doing, what can I expect to pay for such a service...
10-24-2015, 06:03 PM | #6 | |
10-24-2015, 06:13 PM | #7 |
Mine was $300 for about 2 hrs on the dyno. But it seems like things are a little cheaper here in the south than out in your neighborhood.
10-25-2015, 02:34 AM | #8 |
meowMEOWmeowMEOW
A few pulls and 10-15 minutes logging on road for a stock tune should by 250-350...provided they are actually looking into the trans problem and not just tossing another stock flash in there and calling it good. You should be able to give your tuner feedback in terms of shift points, firmness etc so you have the feel you want.
Once combo's get more complicated, or you start going into Custom OS and all that, tunes start going $350-650+, as the total amount of time (road, dyno, smoothing) can drastically increase.
10-25-2015, 05:41 PM | #9 |
I just got quoted $550 from a local shop. I am having the same trans. problem on my ls1.
10-25-2015, 06:36 PM | #10 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
