Old 10-22-2015, 09:11 PM   #1
jdl71
jdl71's Avatar
Source for new 15" steel wheels
Has anyone tried these? Any idea why they would not work?
http://www.etrailer.com/Tires-and-Wh...r/AM20514.html
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-22-2015, 10:05 PM   #2
Gianyveedub
Gianyveedub's Avatar
Re: Source for new 15" steel wheels
I don't know if anyone has, but it looks like I found my source for my rims...
Gianyveedub is offline   Reply With Quote
Old 10-22-2015, 10:25 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
https://www.etrailer.com/question-47764.html
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-22-2015, 10:30 PM   #4
LostMy65
LostMy65's Avatar
Actually, the ones you link do say they meet Department of Transportation Standards.
Old 10-22-2015, 10:32 PM   #5
jdl71
jdl71's Avatar
I'm not sure I'd be real concerned about the DOT business, especially if it was something I wasn't driving every day and not carrying any weight. I'm reading that as more of a "we told you so, so you can't sue us" statement than anything else. At 2600 lbs each, those wheels have plenty of weight capacity for an empty 1/2 ton truck. $200 shipped for 4 brand new powder coated wheels is going to be hard to pass up.
Psalm 23
64 C10
66 K20
Old 10-22-2015, 10:34 PM   #6
LostMy65
LostMy65's Avatar
Yeah, I posted again that those you link are approved DOT.
Old 10-22-2015, 10:38 PM   #7
jdl71
jdl71's Avatar
I read the question you linked to and it said they were DOT approved for trailer use, not automobile. However the response was not directly from the manufacturer but someone saying that's what they were told by them.
Psalm 23
64 C10
66 K20
Old 10-22-2015, 10:40 PM   #8
LostMy65
LostMy65's Avatar
I'm just doing a bunch of googling.
I did find a thread over at Jalopy Journal
http://www.jalopyjournal.com/forum/t...wheels.977269/
Old 10-22-2015, 11:29 PM   #9
Brad54
Brad54's Avatar
I'm curious about the DOT thing... seems like trailer wheels need to hold not only the weight of the trailer, but then also the weight of the vehicle on the trailer.
Also, I've seen trailers turn in tight circles, and the tires deflect a LOT, which tells me the wheels are getting side loads that our vehicle wheels don't see.
I don't think I'd have a problem about running those on a truck.
Now, the question is: Will they clear disc brakes?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-23-2015, 12:55 AM   #10
NVS-C10
NVS-C10's Avatar
There's been a lot of discussion in the suspension section.. read my posts in there.. I actually ordered a pair to try.
http://67-72chevytrucks.com/vboard/s...26#post7333726
NVS-C10 is offline   Reply With Quote
Old 10-23-2015, 01:13 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Is the hub (pilot) hole the correct dimension to clear the spindles, and are the hub centric or lug centric? Those would be my main concerns.
Trailer stuff was popular with the VW bug crowd since so many of the parts were fashioned off of old vw designs anyway and the weight could never be an issue in a sub 2300lb car.
Just remember that trailer wheels and tires aren't rated to handle speed. I would be less enthusiastic about running them on anything that saw 80+ much, or anything that saw high performance use.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-23-2015, 03:06 AM   #12
NVS-C10
NVS-C10's Avatar
The hub hole clears the spindles (it's actually oversized).. check out the write up I did in the link I provided.. the wheels are neither hub centric nor lug centric. The hub hole on these wheels is larger than the factory size of our trucks and the lug holes are for 1/2" studs vs. Our 7/16" studs, so different lug nuts are needed to hold in place properly.
Old 10-23-2015, 06:43 AM   #13
PGSigns
PGSigns's Avatar
I would say to make them center like they should you will need to go to 1/2" studs to get the taper of the lug to pull up on the wheel like it should. Not an issue for the front if you have switched to later disc brakes. The back would need to be drilled for the bigger studs. Either way you do it need to make 100% sure the lug nuts are not pulling up on the drum face.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-23-2015, 01:18 PM   #14
61K10
61K10's Avatar
I bought a set of 16x6 and they are heavy duty rims. yes they are set up for 1/2" wheel studs. center hole fits perfect on my 61k10. I have some heavy-duty 7/16 lug nuts that fit perfect in the lug holes. (the taper for 7/16 and 1/2 are the same) problem is the stock wheel studs are to short. you are gonna have to replace the studs one way or the other. I have the lug nuts so i might stay with 7/16 studs. no tires yet---------
the lugs came from summit and the do have 1/2" ones. as PG said about bottoming on the drums--the little stock ones look like they do. the big ones i don't think so. we will see.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-23-2015, 01:41 PM   #15
jdl71
jdl71's Avatar
Did you but the 15s or 16s? I did not see which ones were being discussed in that thread.
Psalm 23
64 C10
66 K20
Old 10-23-2015, 02:04 PM   #16
61K10
61K10's Avatar
I bought 16's but you were asking about about 15" the center hole is the same on 15 and 16" 3.65 both 1/2" studs. price is great compared to some 50 yr old rusty stuff.
1961 chevy K10
Old 10-23-2015, 02:36 PM   #17
Dans1960SWB
The video is very informative on how to measure a wheel.
Dans1960SWB is offline   Reply With Quote
Old 10-23-2015, 03:32 PM   #18
NVS-C10
NVS-C10's Avatar
I bought 15's for a C10.. good price for what they are but wouldn't buy again. Hub centric is the best way to fit a wheel and these are not hub centric for our 2WD C10's. Hub centric will prevent wheel vibrations and added stress to wheel studs.
Also too as I mentioned in my write up in the suspension section; 64-66 center caps were impossible to put on without having to damage them and then I'm sure they still would not seat correctly.
Old 10-23-2015, 06:36 PM   #19
jdl71
jdl71's Avatar
I did see what you wrote about the caps not fitting. For me that would pretty much nix the deal.
Psalm 23
64 C10
66 K20
Old 10-23-2015, 10:57 PM   #20
NVS-C10
NVS-C10's Avatar
Yeah that was a sad moment for me lol
Old 10-25-2015, 07:34 PM   #21
LostMy65
LostMy65's Avatar
I wasn't familiar with the term 'Hubcentric', so I looked it up.
Are the 73-87 4x4 6-Lug wheels Hubcentric?
Old 10-25-2015, 08:24 PM   #22
jdl71
jdl71's Avatar
I was always of the understanding that almost all OEM wheels are hub centric, and after market wheels are lug centric as they are designed to fit more than one make/model.
Edit: I guess I should preface my statement with the fact that I quit paying attention to most anything newer than '87 or so, when the OEMs went to integrated wheel bearings, IFS 4 wheel drives, etc.
Psalm 23
64 C10
66 K20
