Old 10-26-2015, 09:21 AM   #1
The1960APE
The1960APE's Avatar
6.0 into a 1961
I have looked over and over but cannot find any info on swapping a 2001 LQ4 into a 1961 Apache.
I cannot find a motor mount kit, I have no mounts right now. What do you guys suggest?
I also cannot find any info about the crossmember, does it need to be swapped? If so to what?
The1960APE is offline   Reply With Quote
Old 10-26-2015, 03:17 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0 into a 1961
Your swap shouldn't be any different than the other 60-62 guys, and it will still have plenty of shared components with the 63-66 swaps, which there are many of. You might be able to get more ideas, faster, by taking a look at what the other 60-62's have put together. The "what ya got" thread up top is also helpful for general ideas, and to point you in the direction of members with similar swaps.
IS the 61 stock right now? Drum brakes, X-frame(iirc) etc
So many of these trucks have had 30+ years of changes, so its not uncommon to find modified frames, swapped crossmembers and brakes (especially this!) and other changes.
Motor mount suggestions will be based partially on this^. Its kinda like throwing darts at a parts list until we know exactly what your working with (and what you want to do with it). Just on mounts for example, people have used everything from swap adapter plates, homemade mounts, aftermarket perches/stands, and entire custom xmembers. In many cases, all of the above can be made to work.
So, there I made things 20x more complicated.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-27-2015, 07:56 AM   #3
The1960APE
The1960APE's Avatar
Re: 6.0 into a 1961
It is stock with the exception that I just did a 5 lug conversion and disc brakes all the way around!
I talked to CPP yesterday and ordered
6372MP-SM BLACK SHEET METAL SMALL BLOCK MOTOR PERCH (PR) 1963-72 CHEVY TRUCK W/ SMALL BLOCK V8
LS1-KULAC-P ADJUSTABLE LS ENGINE ADAPTER BRACKETS KIT WITH POLY-PLUS PADS (WORKS WITH LOW AC)
We are going to weld the mounts in place
I also ordered the Thorley headers!
HEY I LIVE IN BREW CITY.................................LOL
Old 10-27-2015, 10:28 AM   #4
The1960APE
The1960APE's Avatar
Re: 6.0 into a 1961
One thing I am wondering, and I know I will not know for sure until I do the mock up is...will I need to change oil pans?
Old 10-27-2015, 12:02 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: 6.0 into a 1961
Yes
Hart_Rod is offline   Reply With Quote
Old 10-27-2015, 01:23 PM   #6
The1960APE
The1960APE's Avatar
Re: 6.0 into a 1961
Originally Posted by Hart_Rod View Post
Yes
Which pan do i need?
