71 c10 heater flap
So I have a 71 c10 w/o ac and the heater gets warm but not hot. when i adjust the heat control lever it doesn't change the temp of the air. i have already flushed the heater core and put a new thermostat in and it hasn't changed. so i am thinking it is the control flap. does anyone have a pic on how the flap works and how to access it.
The Older Generation
Re: 71 c10 heater flap
It is probably full of mouse nest. That will keep the diverter door from moving and it will also restrict the air flow..... A common problem in these trucks. LockDoc
thats what i am thinking, just not sure if there is an easy way to access it or do i have to pull it all the way apart.
#4 | |
LockDoc
Got it fixed. The cable to the flap came unhooked inside the box. Now it is very hot. Crazy that something sp simple caused me to freeze in the winter.
#6 | |
.... Glad you found the problem and it was easy.LockDoc
| Bookmarks |
